Pants 0 Posted May 9, 2006 Report Share Posted May 9, 2006 Hi,Can't get my head aound this one...Perfect when cold, no hunting, no stalling.Progressively get worse as it heats up.Up to full temp she will hunt on idle and stall at lights etc.Any ideas?Cheers. *-) Link to post Share on other sites
vr6turbo 27 Posted May 9, 2006 Report Share Posted May 9, 2006 the best advice i can give is to find someone with vag com and get it scanned Link to post Share on other sites
Nerih 0 Posted May 9, 2006 Report Share Posted May 9, 2006 check idle stabilization valve if its odb1 (check the guides section for information), if its temperature related, check the thermo (blue wire sensor) Link to post Share on other sites
MOZ-IIIVR6 0 Posted May 10, 2006 Report Share Posted May 10, 2006 I have recently had a similar problem. no probs when cold but as it gets upto temperature, poor idling and eratic missfire at low revs ( especially when pulling away) until revs up above 2k ( then Ok again) Mine turned out to be HT leads ( even though it had had a brand new set on at Xmas 2005 :@ seems they were nicked when they were put in)i don't know why the temperature of the engine efffected this unless the plugs and leads were getting hot and some expansion somewhere was opening a crack?Also just had a engine speed sensor problem this last week which towards the end was causing some dodgy running at idle , its probably not this as the main problem I had with this was the fact that the engine wouldn't start at all when warm.Hope this helps.Regards.Moz Link to post Share on other sites
Eat this 2 Posted May 10, 2006 Report Share Posted May 10, 2006 clean the tb with cARb cleaner mine did exactly this now its perfect Link to post Share on other sites
