6potmkII 0 Posted May 15, 2006 Report Share Posted May 15, 2006 got the car onto vag com as the car missfires/loses power and doesnt run on all cylinders when warm.its an obd2 lump in a mk2.here are the codes and explainations from the report, im not sure how to resolve all the problems:00668 - supply voltage to terminal 30 signal too low intermitant01247 - shareware version to decode all dtc's00553 - shareware version to decode all dtc's00281 - vehicle speed sensor g68 no signalhow do i go about sorting the above problems out?cheerskomi Link to post Share on other sites
mk3anni 0 Posted May 15, 2006 Report Share Posted May 15, 2006 00668, mine has that, vince says ignore it, so i do01247, Pay for the software00553, As above00281, Mr bens had that and still put down a healthy 201 bhp.I think the middle 2 are going to be relevent to you. I've checked my copy but i cant work out how to look the codes up..... Link to post Share on other sites
6potmkII 0 Posted May 15, 2006 Author Report Share Posted May 15, 2006 my problems got to be something to do with these. maybe the codes need to be erased in order for it to run properly....plugs, leads, coilpack have all been changed, hall sensor been cleaned, one thing i am worried about tho is my maf. its a new one from gsf but i think there recon'd. when i fitted it, it didnt run as good as one i tried off a mates car. Link to post Share on other sites
mk3anni 0 Posted May 15, 2006 Report Share Posted May 15, 2006 I dunno, i tried reading the DAT file but its all in code, so no use to me, if they wern't important they'd not make you pay for them!! Link to post Share on other sites
vr6turbo 27 Posted May 16, 2006 Report Share Posted May 16, 2006 the g68 is the sensor on the back of the gearbox whuch tell the speedo an ecu how fast you are goingthere may be a wire off or a knackered sensorcheck for voltage on either the blue/yellowor the blue /white wire terminal 30 may be the ecu live feed at the ecu plug Link to post Share on other sites
6potmkII 0 Posted May 16, 2006 Author Report Share Posted May 16, 2006 would the g68 sensor cause misfire or loss of power? Link to post Share on other sites
spindat45 0 Posted May 17, 2006 Report Share Posted May 17, 2006 got the car onto vag com as the car missfires/loses power and doesnt run on all cylinders when warm.its an obd2 lump in a mk2.here are the codes and explainations from the report' date=' im not sure how to resolve all the problems:00668 - supply voltage to terminal 30 signal too low intermitant01247 - shareware version to decode all dtc's00553 - shareware version to decode all dtc's00281 - vehicle speed sensor g68 no signalhow do i go about sorting the above problems out?cheerskomi[/quote'] I have some probable causes for some of these codes 00668 - Engine control Module (ECM) supply voltage low. Battery, wiring, engine control relay.01247 - Evaporative emission (EVAP) canister purge valve. Wiring, fuse, canister purge valve.00553 - Mass air flow (MAF) sensor. Intake leak, wiring, MAF sensor.00281 - Vehicle speed sensor (VSS). Wiring, speedometer, VSSThese are only probable causes! Most of them would cause you some sort of running problems. Hope they are of some help.Kevin Link to post Share on other sites
6potmkII 0 Posted May 17, 2006 Author Report Share Posted May 17, 2006 got the car onto vag com as the car missfires/loses power and doesnt run on all cylinders when warm.its an obd2 lump in a mk2.here are the codes and explainations from the report' date=' im not sure how to resolve all the problems:00668 - supply voltage to terminal 30 signal too low intermitant01247 - shareware version to decode all dtc's00553 - shareware version to decode all dtc's00281 - vehicle speed sensor g68 no signalhow do i go about sorting the above problems out?cheerskomi[/quote'] I have some probable causes for some of these codes 00668 - Engine control Module (ECM) supply voltage low. Battery, wiring, engine control relay.01247 - Evaporative emission (EVAP) canister purge valve. Wiring, fuse, canister purge valve.00553 - Mass air flow (MAF) sensor. Intake leak, wiring, MAF sensor.00281 - Vehicle speed sensor (VSS). Wiring, speedometer, VSSThese are only probable causes! Most of them would cause you some sort of running problems. Hope they are of some help.Kevin did u get these from autodata? Link to post Share on other sites
VR6Rich 3 Posted May 18, 2006 Report Share Posted May 18, 2006 Heres a link to fault codes from the Bentley website. http://www.bentleypublishers.com/tech/vw/vw.dtc.table.htmDoesnt have your codes though. :-( Link to post Share on other sites
antera309 3 Posted May 19, 2006 Report Share Posted May 19, 2006 http://www.vr6oc.com/images/Guides/faultcodes/vwcode.pdf Link to post Share on other sites
FishWick 21 Posted May 19, 2006 Report Share Posted May 19, 2006 ECU terminal 30 is indeed the live feed and every time you disconnect the battery or pull the ECU plug, it will store it as a fault code. Nothing to worry about.My OBD2 ran like cack when it was running too lean, coughing, missing, etc etc So I'd suspect the MAF as the primary cause. Link to post Share on other sites
6potmkII 0 Posted May 19, 2006 Author Report Share Posted May 19, 2006 iv jus bought a new maf and fitted it. same thing. theres jus no power at high revs and the power delivery is intermittant. comes in and out. could it be a weak fuel pump? can this cause this as my 8v one is on its last legs , constant loud whining. and it doesnt juder like a proper missfire, just loses power smoothly if you kno what i mean. everything else has been changed, plugs, leads, maf, coilpack,cleaned hall sensor......what else can it be. the only codes that came up on vag com where the above ones.... Link to post Share on other sites
6potmkII 0 Posted May 20, 2006 Author Report Share Posted May 20, 2006 come to think of it, i think its the fuel pump. is it a possibilty? Link to post Share on other sites
spindat45 0 Posted May 24, 2006 Report Share Posted May 24, 2006 got the car onto vag com as the car missfires/loses power and doesnt run on all cylinders when warm.its an obd2 lump in a mk2.here are the codes and explainations from the report' date=' im not sure how to resolve all the problems:00668 - supply voltage to terminal 30 signal too low intermitant01247 - shareware version to decode all dtc's00553 - shareware version to decode all dtc's00281 - vehicle speed sensor g68 no signalhow do i go about sorting the above problems out?cheerskomi[/quote'] I have some probable causes for some of these codes 00668 - Engine control Module (ECM) supply voltage low. Battery, wiring, engine control relay.01247 - Evaporative emission (EVAP) canister purge valve. Wiring, fuse, canister purge valve.00553 - Mass air flow (MAF) sensor. Intake leak, wiring, MAF sensor.00281 - Vehicle speed sensor (VSS). Wiring, speedometer, VSSThese are only probable causes! Most of them would cause you some sort of running problems. Hope they are of some help.Kevin did u get these from autodata?Sorry, i forgot to check back on this thread. Yes they are from Autodata CD. Not much help I take it? Link to post Share on other sites
vr6turbo 27 Posted May 25, 2006 Report Share Posted May 25, 2006 vag com is what you need for us to be able to cross reference the codes Link to post Share on other sites
vr6turbo 27 Posted May 25, 2006 Report Share Posted May 25, 2006 whats the fuel filter like ?a cheap option before getting a fuel pressure test done Link to post Share on other sites
6potmkII 0 Posted May 25, 2006 Author Report Share Posted May 25, 2006 fuel filters brand new, its an mk2 so only an 8v pump but they run at higher pressure than the vr6 i believe. its just that the fuel pump nackered i think, as it doesnt loose power as bad when its a full tank, and also the pump doesnt whine as much. Link to post Share on other sites
spindat45 0 Posted May 25, 2006 Report Share Posted May 25, 2006 Get yourself a VR6 pump m8. My cousin had a similar problem after he had his VR conversion done on his MK2. The difference that the VR pump made was amazing. Kevin Link to post Share on other sites
