Guy 1 Posted June 10, 2006 Report Share Posted June 10, 2006 ok so how do i check out the auxillary water pump then ?It doesnt come on when you put the ignition on and it doesnt stay on after either.Any easy checks i could do ? or is it just take it off and inspect it ? If it's knacked then bin and replace ?Do they have their own relay ? if so which one .I've checked all the fuses and theyre all good.It's been like it for 18 months now with no detrimental effects or so it would seem. Link to post Share on other sites
Eat this 2 Posted June 10, 2006 Report Share Posted June 10, 2006 its almost certainly knackered mate just get a new 1 Link to post Share on other sites
fritzenberg 3 Posted June 10, 2006 Report Share Posted June 10, 2006 if you turn the ignition key half way `till the electrics come on,but don`t start engine,open the bonnet and you should hear a buzzing sound coming from the right hand side of the engine,that`s motor in the pump working.so,no buzzing sound = burt out pump.hope this is helps. Link to post Share on other sites
SankysVR6 1 Posted June 10, 2006 Report Share Posted June 10, 2006 Check for the voltage on the plug that goes to the Aux water pump when the ignition lights are on. If the 12V is there and there is no humming sound when the cable is connected the pumps burnt out. Link to post Share on other sites
badboyV6 4 Posted June 11, 2006 Report Share Posted June 11, 2006 Also check the 5 amp fuse below the coolant resrvoir - mine was blown.... And from what i told this is for the auxillary water pump. Link to post Share on other sites
Guy 1 Posted June 11, 2006 Author Report Share Posted June 11, 2006 Sorry I'm slow responding the suns been a great lure.Thanx for the replies though.I'll go check it out this evening when it cools down a bit.Just out of curiosity, has anyone got an idea on price from the stealers or do gsf do them or has anyone got one spare for sale? Link to post Share on other sites
Guy 1 Posted June 11, 2006 Author Report Share Posted June 11, 2006 Well, after checking it out earlier there is the correct voltage to the pump and the pump is showing no resistance thus pointing the finger at the motor being burnt out.So it's new pump time.Thanx for the pointers. Link to post Share on other sites
Guy 1 Posted June 14, 2006 Author Report Share Posted June 14, 2006 Right theres been a little development , I walked into GSF today and bought a new pump.. hurrahGot home let it cool down a bit and whipped off the cover and just out of curiosity plugged it in and it worked a treat so I switched the ignition off to see if it ran on after and it didnt .Are they supposed to ? my bros does.Any reason why it shouldnt run on ? relay ?Any suggestions anyone ? Link to post Share on other sites
spindat45 0 Posted June 14, 2006 Report Share Posted June 14, 2006 I think that it only runs on after the key has been taken out if the fans are running. This so that the coolant continues to be circulated around the engine after turning off. Much needed on these babies as they run so hot. When the fans go off so does the aux pump. Its not as easy to hear the aux pump when the fans are going though.Kevin Link to post Share on other sites
Guy 1 Posted June 14, 2006 Author Report Share Posted June 14, 2006 Ahh right, so I need to run it up and get it hot and see then . makes sense really I suppose.I just didnt want to fit it and find that there was another issue.So I guess I'll do it after work tomorrow then.Nice one cheers Kevin.BTW was £75 from gsf if anyone was interested and a gen Bosch one too. Link to post Share on other sites
J5KE F 0 Posted June 14, 2006 Report Share Posted June 14, 2006 bonus! i need 1 of them! thanks guys... Link to post Share on other sites
Guy 1 Posted June 15, 2006 Author Report Share Posted June 15, 2006 Right... so i got home from work early today and let the car cool down enough to work on.Swapped out the aux water pump and topped up with antifreeze.i let it get up to temp and the fan cut in once or twice and then whist still running switched the car off and the pump wasnt running when i put my hand to it.Surley it should be running for a bit.I reckon there must be a relay for it and its had itIdeas anyoone ?Or can anyone tell me for sure if theirs runs for definate when they stop.thanx in advance. G. Link to post Share on other sites
SankysVR6 1 Posted June 15, 2006 Report Share Posted June 15, 2006 It should run regardless if the fans have come on or not. Basically if you turn the ignition lights the aux pump should start pumping, turn the ignition off and the pump should continue running for a futher 10mins or so.Im not sure why yours isn't running once the ignition has turned off, but i will have a look in the Bentley for you and post back Link to post Share on other sites
Guy 1 Posted June 15, 2006 Author Report Share Posted June 15, 2006 cracking .thank you. I may even ring Vince tomorrow and see if he's any idea. Link to post Share on other sites
fredfelcher 0 Posted June 18, 2006 Report Share Posted June 18, 2006 You can check it by jumpering the coolant temp sensor (yellow switch in thermostat housing, in front of coil pack high up on engine block).1 Switch ignition on briefly then off2 Unplug switch and jumper terminals 1 and 33 Fans and pump should run.Terminals: with retaining clip uppermost, looking at terminals, 1 is upper right (brown/red wire at back) and 3 is bottom left (brown wire).Hope this helps - tried to do diagram but stupid forum formatting kept messing it up. Link to post Share on other sites
Guy 1 Posted June 18, 2006 Author Report Share Posted June 18, 2006 Right I'll go check it out now and top the oil while im there as i'm sure it needs doing.Oh what happens if it doesnt then stay on ? sensor buggered ?Thanx for the reply Richy. Link to post Share on other sites
J5KE F 0 Posted June 18, 2006 Report Share Posted June 18, 2006 Just to let you guys know, we enquired about an auxillary water pump from Euro car parts, and they quoted us £16.00doesnt make sence to me, but if its tru and they are, I'm going to buy 3!!! Link to post Share on other sites
Guy 1 Posted June 19, 2006 Author Report Share Posted June 19, 2006 If it's true and they are then let me know and I'll put a few f*cks into gsf and get a refund.Still after shorting the terms the pump and fan both spun up like they should but the pump didnt stay on any longer than the fans.I guess the huge relay on the nsf wing may have a fault but i'm poking in the dark here a bit. Link to post Share on other sites
J5KE F 0 Posted June 19, 2006 Report Share Posted June 19, 2006 I was chattin to someone at Inters chap and apparently when the Resevoir blows off the relays can get a nice hot bath.. another semi common fault!Jake Link to post Share on other sites
Guy 1 Posted June 20, 2006 Author Report Share Posted June 20, 2006 They've had a little bath on one occasion so it wouldnt surprise me if it was a gonna.It's a bloody mystery though.Next time i'm at me bros ill pinch his and see if it makes any differance.Do a side by side comparison so to speak.It would defo clear the issue up as it niggles me somewhat.Thanks for the info . Link to post Share on other sites
