Jeff_VR6 0 Posted June 2, 2004 Report Share Posted June 2, 2004 My VR6 will not start unless I keep the key turned at the start position for over 5 seconds... The engine does turn over as I can hear it, but this doesn't sound right..Any ideas?Btw I got a video of me starting the car and you can clearly hear the engine struggling.. PM me if you want it.ThanksJeff Link to post Share on other sites
28v6r 0 Posted June 2, 2004 Report Share Posted June 2, 2004 Oh go on then I'll bite!! Send it to me for a listen 8o) Link to post Share on other sites
Eat this 2 Posted June 2, 2004 Report Share Posted June 2, 2004 me too Link to post Share on other sites
acf8181 0 Posted June 2, 2004 Report Share Posted June 2, 2004 i've had a problems staring recently...is the starter motor.but mine's different to yours i suspect, mine doesn't turn over and the lights fade (as tho battery is dead), but then if i keep trying it'll suddenly just start!think i may have sussed the best way to do it. if i pump the throttle twice then just turn the key it starts!but usually (and thi is from my racing!) the best way to start a car is to turn the key, then press the throttle to about quarter throttle. works everytime (unless its fu**ed up like mine!) Link to post Share on other sites
Jeff_VR6 0 Posted June 7, 2004 Author Report Share Posted June 7, 2004 How big a job is it to change the starter motor? And the costs?Thanks Link to post Share on other sites
acf8181 0 Posted June 7, 2004 Report Share Posted June 7, 2004 well....i got givena red herring by the garage and it turned out to be the battery.theres a starter on ebay at the mo, they're £115 new. it doesn't look like that biug a job, but you have to support the engine. Link to post Share on other sites
Jeff_VR6 0 Posted June 11, 2004 Author Report Share Posted June 11, 2004 Ah damn. The labour cost in my area is ridiculously high. I live in Hong Kong, that may explain part of it... And no one, well rarely anyone, in Hong Kong knows VWs well... let alone the VR Link to post Share on other sites
FishWick 21 Posted June 11, 2004 Report Share Posted June 11, 2004 Hmmm, so it cranks over but doesn't fire? It might be the ignition switch from what you've said. Have you tried wiggling the key about as you turn it? How old is the car? Might have a dodgy transponder in the key if you've got a factory immobiliser. Prolonged VR starts are generally caused by a crank sensor that's losing it's resolution or some kind of ignition related problem.Just a few more ideas for the melting pot..... Link to post Share on other sites
dub_weiser 0 Posted June 11, 2004 Report Share Posted June 11, 2004 There £100 + VAT from a VW dealer, mine needs replacing too. Link to post Share on other sites
Jeff_VR6 0 Posted June 13, 2004 Author Report Share Posted June 13, 2004 mine is a late 1994 model. OBD1.. It should be UK spec as i imported it privately to Hong Kong (with all the luxuries.. leccy windows, heated recaros... etc etc) Link to post Share on other sites
ingham 5 Posted June 14, 2004 Report Share Posted June 14, 2004 jeff have you sorted your coolant loss yet as it may be related Link to post Share on other sites
Jeff_VR6 0 Posted June 14, 2004 Author Report Share Posted June 14, 2004 really?how can it be related?sorry i'm not questioning your suggestion in any way but i'm no mechanic and i don't understand how that could happen...thanksjeff Link to post Share on other sites
Jeff_VR6 0 Posted June 14, 2004 Author Report Share Posted June 14, 2004 oh and no i haven't had time to sort it out... it's sitting in my garage now the downside is... i'm using a vauxhall vectra and a toyota camry for my daily journeys... ... the camry is fine but the vectra is total shite... the engine sounds like a diesel when it is a 2.0L petrol lol Link to post Share on other sites
ingham 5 Posted June 14, 2004 Report Share Posted June 14, 2004 coolant loss into plugs(piston /conbustion camber) due to headgasket blown may need to turn over to and over clear plugs to fire hense poor starting but must admit might not be ,hard to say not able see car (if head gasket leaking just a bit will still run fine till starts to leak more ) garage should be able to test coolant for conbustion gases to see if headgasket is problem ,its a simple test only a 2 min job Link to post Share on other sites
