Norrisvr6 0 Posted June 13, 2006 Report Share Posted June 13, 2006 Today i was driving along in my 1996 vr6 and the airbag light is coming on for some reason. What does this mean? Is it just a problem with the airbag or can there be anything else wrong? Also apart from a Vag thing what other way can i get rid of the problem? Many thanks :-p Link to post Share on other sites
mk3anni 0 Posted June 13, 2006 Report Share Posted June 13, 2006 It means the airbag has a problem. You need to find someone with vag com who can plug in and tell you whats up and clear the code. Link to post Share on other sites
Norrisvr6 0 Posted June 13, 2006 Author Report Share Posted June 13, 2006 So no other side effects of it being on? Surely u can jst take bulb out of light then? Link to post Share on other sites
riggs 0 Posted June 13, 2006 Report Share Posted June 13, 2006 Or buy a fault code reader of Egay for £20+p+p You can then read and clear fault codes Link to post Share on other sites
Norrisvr6 0 Posted June 13, 2006 Author Report Share Posted June 13, 2006 you sure? i can only find draper one and it seems 2 jst read wots up? Link to post Share on other sites
Norrisvr6 0 Posted June 13, 2006 Author Report Share Posted June 13, 2006 see when i start it the lights goes on blinks for a split second goes off and come back on Link to post Share on other sites
mk3anni 0 Posted June 14, 2006 Report Share Posted June 14, 2006 if the lights on the airbags wont work. depends how much you want them I guess.I was under the impression the fault code readers where just readers, and are not able to clear the codes. Link to post Share on other sites
fredfelcher 0 Posted June 18, 2006 Report Share Posted June 18, 2006 Most of the readers can't clear the codes, you need to get to VAG-COM or similar.You can't just remove the bulb - it'll fail its next MOT if the light doesn't come on then go out. Link to post Share on other sites
mk3anni 0 Posted June 18, 2006 Report Share Posted June 18, 2006 Not true. The light doesn't have to come on at all. That rule only applies to the ABS system. Link to post Share on other sites
VR6Rich 3 Posted June 19, 2006 Report Share Posted June 19, 2006 Not true. The light doesn't have to come on at all. That rule only applies to the ABS system.I was just going to say that Steve as I know this first hand ;-) Link to post Share on other sites
ian 182 0 Posted June 19, 2006 Report Share Posted June 19, 2006 Surely this must just be a faulty wire.My clio seat belt light came on on my 05 182 and it turned out to be me putting the seat to far back and unplugged the sensor under the seat.it must be something simpleian Link to post Share on other sites
fredfelcher 0 Posted June 20, 2006 Report Share Posted June 20, 2006 Oh right, sorry for the duff info. Link to post Share on other sites
