ian 182 0 Posted June 19, 2006 Report Share Posted June 19, 2006 When im in my car and go to pull off or reverse i notice a judder from the engine.Its only at low revs but its noticable.any ides folksian Link to post Share on other sites
Whitedog 0 Posted June 19, 2006 Report Share Posted June 19, 2006 You havent been putting Metz in the tank have you???? Link to post Share on other sites
wakdog 0 Posted June 20, 2006 Report Share Posted June 20, 2006 check the basics, spark plugs and leads. Mine did this a while ago and it was because the 1st spark plug had a greasy buildup on it and was obviously not firing properly Link to post Share on other sites
spanky 0 Posted June 20, 2006 Report Share Posted June 20, 2006 Could be the clutch! Link to post Share on other sites
clarkie 1 Posted June 20, 2006 Report Share Posted June 20, 2006 spend a bit of time checking all the wires on the main wireing loom plug as i had a wire broke there on mine . that mad it misfire and was even worse in reverse. also check all the wires that go to the mass air flow sensor and all the other wires. its worth it before you go forking out loads of cash. Link to post Share on other sites
ian 182 0 Posted June 21, 2006 Author Report Share Posted June 21, 2006 cheers guysian Link to post Share on other sites
