Here's the symptoms i've noticed over the past month or so:
strong smell of fuel when starting from cold
lumpy/rough idle whether engine hot or cold
when sitting at idle engine revs drop if you turn steering to full lock or if you continue to hold the electric window switch down even when the window has fully raised (it's like the engine struggles to meet the electrical demands at idle power setting)
The car drives ok, it can e a bit lumpy under acceleration, especially in 5th when going round a corner. I've checked plugs/leads, also cleaned the ISV, all to no avail. I have noticed a hissing noise coming from the rear of the engine bay, it's coming from a small square plastic box with rounded edges to the back of the engine bay, the object has a couple of tubes coming out of it.
What could be causing this problem, what should i check / clean to get my motor running smoothly again? :S
