Frazer 0 Posted June 28, 2006 Report Share Posted June 28, 2006 Hi folks, I'm new to VR6's but not to vee-dubs, had several air-cooled and a couple of Golf's in the past.Bought myself a lovely N reg VR6, basic model in mint condition at 113K miles.. Love the torque, love the delivery, love the understated looks (she's de-badged in cadbury metallic purple), not so keen on the soft suspension but hey, its a completely stock car.I have an engine problem which has materialised after cleaning the throttle body. I had the TB cleaned as at idle the revs were not settling properly after warm up - nothing too much, just wavering around the 900 to 1000rpm. Now the engine is ok at idle but over revs when in gear with no gas. e.g. I'm in say 4th and the car will pull without any throttle at around 1700rpm. It is as if the engine is over compensating when under slight load. Reconnecting the TB plug improves the problem but only for a short period.I'm new to such an advanced engine, having a better understanding of pots, pistons, and carb type tuning. Any ideas? Do I need to replace the throttle body? If so what's the damage? Same on the air mass meter? Any other likely faults? Link to post Share on other sites
DundeeDub 0 Posted June 29, 2006 Report Share Posted June 29, 2006 check that the throttle cable is fitted properly and has not slipped over the grove over the side of the black plastic curved thing, you'll know what i'm on about when you see it Link to post Share on other sites
Russ_vr6 12 Posted June 29, 2006 Report Share Posted June 29, 2006 i would also suggest that it sounds like a poss vacuum leak,chck that the tb is tighened up and the gasket isnt sitting funny matesounds like unregulated air getting in to me Link to post Share on other sites
Frazer 0 Posted June 29, 2006 Author Report Share Posted June 29, 2006 Ok, so everything is tight and connected correctly. What is weird is that when I disconnect, re-connect the cables to the TB - the problem impoves then gets worse again which leads me to believe that the problem is internal to the TB.What is the cost of a new TB?Is this a DIY job?Also, what role does the air mass meter play - should I replace it? Link to post Share on other sites
FishWick 21 Posted June 29, 2006 Report Share Posted June 29, 2006 An N reg could be OBD2. Does yours have an idle valve? If not then it's OBD2, in which case the throttle position sensor could be worn. The bad news on OBD2 is the throttle is a sealed unit and costs £250+VAT from VW!If it's OBD1, you can replace the throttle sensor. £40 from VW.Sounds like the ECU is readapting itself everytime you remove and replace the plug, hence the short lived improvement.Find out if it's OBD1 or 2 first.... there's a sticky thread about it somewhere. Link to post Share on other sites
Frazer 0 Posted June 29, 2006 Author Report Share Posted June 29, 2006 Looking at the stickt thread on throttle bodies - I'm pretty sure I have an ODB2.Do other suppliers (e.g. German & Swedish) sell TB's? Is there a cheaper option than VW?Also, is replacing the TB a DIY job? Link to post Share on other sites
VR6Pete 1,455 Posted June 29, 2006 Report Share Posted June 29, 2006 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?118088 Here is that thread. Link to post Share on other sites
Frazer 0 Posted June 29, 2006 Author Report Share Posted June 29, 2006 So I checked out the cost of getting a new TB - around £350 from VW..My local VW spares shop however can get them straight from the manufacturer for £168 plus VAT. Do you guys think that it is worthwhile replacing the TB? Note that I have had the TB cleaned and re-calibrated by my VW approved mechanic, and still have the over revving issue. Link to post Share on other sites
dellert 0 Posted June 29, 2006 Report Share Posted June 29, 2006 I had a similar problem on my mk2 carb, it was a stick throttle cable, used to have to hook my foot under the pedal to kill the revs. When you say you disconnect the cables do you mean the throttle cable or you tlaking about electrcal wires? Link to post Share on other sites
Frazer 0 Posted June 29, 2006 Author Report Share Posted June 29, 2006 The electical cables to the throttle body. The throttle body is much different to a carb on a Mk2. My problem isn't so much a stuck throttle, more like the ECU is over compensating when the engine is under load. Link to post Share on other sites
dubberVR6 0 Posted June 29, 2006 Report Share Posted June 29, 2006 Would a Vag-Com diagnostic not pick up if it was a problem with the TB? Link to post Share on other sites
Dave Lea 4 Posted June 29, 2006 Report Share Posted June 29, 2006 depends who is reading it Link to post Share on other sites
dubberVR6 0 Posted June 29, 2006 Report Share Posted June 29, 2006 Ok............. It might be worth the small investment first though. Link to post Share on other sites
Frazer 0 Posted June 30, 2006 Author Report Share Posted June 30, 2006 What is a Vag-Com reader? Is that the fault code device that plugs into the dash by the lighter? Link to post Share on other sites
FishWick 21 Posted June 30, 2006 Report Share Posted June 30, 2006 VAG-COM is a bit more than that, it translates the error codes for you and runs from a laptop/PC.OBD2 ECUs can be forced to adapt the throttle and you can also check it's operation in the measuring blocks.Shame you're so far away otherwise I'd check it over for you.When you turn the igntion on for the first time, can you hear the throttle making a high pitched whine and clonk a couple of times? This is the adaptation process. If it's silent, it indicates a problem! Link to post Share on other sites
Frazer 0 Posted June 30, 2006 Author Report Share Posted June 30, 2006 On start up the car revs to about 1800rpm then wavers a bit before settling to around 1000-1100rpm for a couple of mins then down to 900.The issue is when the engine is warm and I've accelerated in any gear - after I come off the gas, the revs stay between 1700 to 2000, thus pulling the car on the flat. Out of gear the car gradually comes back to idle around 900.I've got a good deal on a new throttle body, should be able to get it fitted & calibrated all in for about £200. As the car has done 114K now, that might be wise huh?Thanks for the offer of the VAG-COM Link to post Share on other sites
FishWick 21 Posted June 30, 2006 Report Share Posted June 30, 2006 Fitting takes about 30 mins and no need to calibrate it, it does that itself. Just switch the ignition on to position 2 and leave it for about 30 seconds. Then you'll hear the noises I explained earlier as it sets itself.Give it a bash and see how you get on. Link to post Share on other sites
lee060 3 Posted June 30, 2006 Report Share Posted June 30, 2006 depends who is reading itfolowing on this , code may not come up in all cases , but . thru good data readings out codes , all depends , if say the person carrimg out the faults can be found with test can be arsed , also if thye know what there looking for , all i can say is dont depend on codes . read the data readings and see if everythings in check Link to post Share on other sites
Frazer 0 Posted July 23, 2006 Author Report Share Posted July 23, 2006 Over revving issue now solved. Sorted compeletely by replacing throttle body. Buying direct from Siemens VDO (OEM manufacturer) proved about 40% cheaper than sourcing part from VW (G&S don't stock them).Got the old ODB2 TB if any one wants it for rebuilding, if that's possible.. 8-) Link to post Share on other sites
