After searching around and getting prces of about £14 each ( I live in Denmark )for Bosch plugs, I found a shop that does Nippon Denso equivalents much cheaper. I actually use Densos on my motocross bike and think they are fantastic.
Anybody tried these before ? Any comments ?
you should just buy the oe ngk ones from 95 and up,i have used the in all my vr´6 (had three)if you live in aarhus you could buy the from NAP,the last set kost around the 500dkr,but iknow the denso plugs are good,but stick too oe,unless you go the charger way.mine a 2.9 syncro with oettinger 210 set.
Regards From
another DANE
