So, I installed a new map sensor and my fuel trim numbers improved greatly. I also found a spot on my CTS intake manifold that is porous and leaks around 25psi. Also, my fuel pressure started dropping and it turns out all my fuel line clamps loosened up on my in-tank walbro 450 fuel pump. Tightened everything up and the car has been running decent. Im buying new submersible fuel hose for the in-tank pump and pinch clamps to keep it all tight. Im going to throw some epoxy on my intake manifold until next winter where I can fix it the right way. Getting closer to a good running 3.2 vrt. Thanks f
