phat28vr6
About phat28vr6
middlesbrough
what exhaust have you got
phat28vr6 replied to rudedubber's topic in Engine Maintenance and Problems
SPEEDTECH 2 1/2 " group A system from richard at Venom....£400 ish!!...135 x 75 upswept oval TP !amazed -
Hall sensor fault - diagnostics
phat28vr6 replied to Macca's topic in Engine Maintenance and Problems
yea mate ...agree with Brett...cam position sensor...not uncommon prob. &| -
Glad you could join us mate...VR heaven lol
Does your engine have a distributer? Or is it D.I.S. with the coil pack... -
i cleaned my fronts once when the ABS light was on permanent...it cured it. There magnets and pick up crap !! [blockquote][/blockquote] [ Edited Mon Nov 03 2003, 05:43PM ]
92-97 degrees for stage one...99-105 for stage two. Try bridging the elecrical connector for the temp sender in the rad...brown is earth...touch to one then the other via a piece of wire.Both speeds should work.If not its the sender.Also check the aux. pump next the distributer and the yellow sender in the water housing.
1HO 121 253 BE (630 x 380mm).My temp runs 75 and the fan comes in at just over 90.Are you sure stage 1 is working on your sender in the rad? [ Edited Sun Nov 02 2003, 01:12PM ]
I've had mine off to replace with new...theres a plastic runner that they fix too the length of the sill...you'd have to remove it and buff the paint or respray it
Yea mate and icl. VAT
Fit a pair of relays mate.I have them fitted with standard bulbs and it looks like ive got high watt bulbs in.Its not the bulbs that are at fault , its the voltage drop!
I use EBC discs with Green Stuff pads and have had no probs...brakes feel a lot sharper too...and theres very little dust so less to clean off!! I payed about £185.Been on 2 yrs and have hardly worn at all so good value I reckon.
thats it mate ...all sorted...no more oiled up TB
Errr..Middlesbrough....not far from Newcastle....you know..we have the shite football team!!
