Richvr6
  1. Richvr6
    LECY WINDOW
    Thanks for the feed back i'll give it a try.
  2. Do the mk2 bonnet lifters fit the mk3? anybody?
  3. how much does that make them then?
  4. anybody know why images are disabled, i'm well keen on seeing the angle eyes fitted, but it just says image disabled instead.
  5. That is one sexy looking VR, what wheels are on it jonvr6highline? Is it yours?
  6. These hose's look the bees. Anybody know how I can get in touch with rally design, I can't seem to find them, thanks in advance. Don't mean to offend but a fiver is two pints in my local, don't know about yours, I can either spend the fiver on a couple of pints or have a posh shit wipe, could even give it to cancer research, either way I?d rather be choosing the destiny of my fiver not lining the pockets of 'Amber'. Thanks in advance, and think about your fiver [ Edited Sat Feb 28 2004, 06:05PM ] [ Edited Sat Feb 28 2004, 06:06PM ]
  7. did you find out were the coolant leak was?
  8. the fan? try putting direct voltage through the motor/fan, if it doesn't work/blow it's the fan/motor, if it does it's the connection between the controls and the fan, you would have to check the continuaty between the control and the fan. If this is ok i would suspect the control panel or relay if there is one these are the only things left, hope this helps. Please post outcome as always handy to know these things.
  9. Richvr6
    LECY WINDOW
    Hello, hope you can help, my drivers side front window, when open and I press the button to close the window, think it's called courtesy function or something like that, approx 70% up, the window stops and then returns to the bottom. This is an intermittent fault but occurs more often than not. Any help or suggestions appreciated
  10. mines doing the same, thought it might be the thermostat, but i just noticed when i turn the heater blower on, the radiator fans also come on? surely this is not normal. Its got climate control no twisty nobber jobs just buttons. I tried driving with the heater off but temp only rose to 70. Any help much appreciated.
