eVil - did you change the cams to the 248's after you put the 'charger on? do you know what sort of power/torque gains you got from the cams alone? cheers sam
The Stroeve one is one of the best looking one's i've seen - but like you say, I don't fancy having to start bending the aircon pipework to get it to fit Are there any other makes around that fit straight on?
Does anyone have one of these or know if the front strut brace fits ok on a Golf with air-con? Does anything else need to be moved to make it fit? Would be interested to hear opinions of what the quality is like too Cheers Sam
I put the exhaust on at the same time as I did a few other mods (schrick vsr/cams, BMC, re-chip etc) so don't know what gains, if any, the exhaust gave on its own As dubloke said I think you can only expect a couple of bhp increase max
I had a similar prob a while ago - grinding noise when driving straight, got worse when turning to the left and seemed to disappear when turning to the right and this turned out to be the wheel bearing
The C2motorsports kit does look quite good - they are offering a group buy on their stage 1 kit on the vwvortex forum for $3300 (approx £1800) plus shipping They said they would ship to the UK and they normally send them as 'gifts' when they ship abroad so you would hopefully not have to pay import duties but I assume you would still pay vat on it
I asked Vince @ Stealth the same question and his advice was to use the 2 prong type plugs (as used in early OBD1 engines) and replace them every 10k miles These plugs are approx £3 each so you end up saving a little compared to if you use the platinum type plugs (approx £10 each) which last for 3 yr's or so
