Days Won
1
MarkGolf last won the day on November 13 2015
MarkGolf had the most liked content!
About MarkGolf
S. London
Hi guys, I've been out of the loop for a little while but trying to get back into it all now. I got my VR6 up and running-ish again, the other day. The gear change hit me straight away, it feels awful!! It's a corrado vr6 setup but in my Golf, I had replaced all bushings in the shifter and it has a gruven short shift (side to side), but the throw from front to rear is enormous and there feels like a lot of play, I put the car into first and the knob then looks like it moves to where 3rd is, its just like a stick in mud. Should I go with an 02J setup or the besters modific
ky_uk reacted to a post in a topic: Fitting Walbro fuel pump in tank
VR6Pete reacted to a post in a topic: Fitting Walbro fuel pump in tank
MarkGolf reacted to a post in a topic: Improve shift feel?
Hi Guys, I know people ask this a fair bit but I feel like I have done everything I can with the 02A shifter to try and improve it.. So, I have a corrado shifter, just because this came with my engine (in a mk3), when trying to find the source of the crap feel I tried a mk3 shifter and made no difference apart from the internal shifter being taller. So anyway, I have replaced every bush within the shifter, I have a gruven short shifter bracket and new bearings in the tower. The big nut on the shifter tower is done up all the way. The shifter just feels crap, literally no feel, it goes into f
bennyk reacted to a post in a topic: Wheeler Dealer: Corrado VR6
I saw the car forsale last month on AutoTrader, had 140 odd k miles.
VR6 won't crank, just a clunk..
MarkGolf replied to MarkGolf's topic in Engine Maintenance and Problems
Thanks mate!! I just finished fitting a new ignition switch and the car no longer seems to be resetting the clocks when cranking although all I am getting is the clunk of the solenoid. I saw your post and I used a jump lead to earth that bolt to the chassis but same clunk, so new starter it is. I'll report back with what happens! Thanks again -
I agree with that.. The starter motor has always been a bit slow to turn over, ever since I completed the car, the car struggled to fire up and when cranking, every time the clocks would reset. I used to have an Optima yellow top battery, the car was the same, lazy and slow to turn over, compared to my mates VR6's which would fire up on the button and really fast. I am going to connect a larger battery up and see what happens, if no improvement, I'll get a new starter motor and keep my fingers crossed. One last question, on 1 of the 2 bolts which hold the starter motor to the gearbo -
ER6 reacted to a post in a topic: VR6 won't crank, just a clunk..
Thanks for your help again! Tried some troubleshooting on it today.. So, the battery is in the boot, I am running 0awg positive and negative. The battery is ground out to the boot floor and the positive runs to a BMW terminal box and then to the starter motor. I am using a BOSCH S4 (560A 60ah) battery.. Possibly a bit weak for the demand on it when cranking.. So, the first thing I did today was run a jumper cable from the start postive to the ignition live on the solenoid, this turned the starter but only just.. This prompted me to try with the key, turned the key and woohoo, car fired up. -
Thanks for the reply. I did give the starter a bit of a tap with a rubber mallet but not as hard as I would have liked as the whole thing has been chrome plated.. Have to be careful when doing anything, complete pain in the arse!! I'm not aware of anywhere that can test the starter, would like to know though. I do have another in bits which was a spare, no solenoid however, just wanted to know if this sounds like a starter issue or not, if so, the actually solenoid or lumpy bit! Thanks -
Hi Guys, Been a while but trying to get my Golf going.. It's not been driven for 2.5 years and the last time I cranked it over was around 6 months ago.. Recently I turned the engine over by hand at the crank before trying by key. I hopped into the car and the car cranked but not enough to fire.. Every attempt there after, it doesn't crank. I can just hear a clunk from the starter motor, I assume this is the solenoid. I have 12.4V at the battery (this is in the boot), I have 12.4v at the starter and there is power at the red/black wire when I crank but I don't get a chance to see the number on
Hi all, I had a starting issue appear when at Early Edition... I came home and stripped the starter motor off after doing various tests. I had to get it off anyway to change the mounting body for a newly chromed one so this was an excuse to do that and give it a once over. I tested the obvious.. Volts across the battery posts, volts across the wire terminals, volts at the starter solenoid, all showed consistent values of 12.9V.. Before the starter was stripped off and then rebuilt, you would turn the key and you could hear the starter make a sound but all power would die and clocks reset. This
Tappety noise after head overhaul...help
Maybe I need to run it slightly longer.. I must have had it running for 20 mins last night while I did my coolant but I didn't really rev it..Just let it idle.. I'm going to re-bleed the tensioner bolt and let it run again.. Cheers -
Hi all, Recently gave my cylinder head a rebuild after my od head had dodgy seals.. Fitted new valves, guides, seals and tappets. I reused the springs and cams but all appeared fine.. I fired the car up for the first time last night and it ran for no longer than 2 mins as I had minimal coolant in there, all sounded perfect.. Tonight I fired it up so I could bleed the coolant system and with 2/3 mins the engine developed a tappety noise, it appears to be coming from cylinder 3/5 area and stats at a steady volume no matter the revs but the noise does match the engine RPM.. Can anyone shed any li
Thanks for that mate, I can finally crack on and get her going again! Cheers
Hi all, Im about to fit my ARP head bolts but there seems to be a lack of info on correct fitment. Do the rods go in until tight or is there a torque? I will be using the lubricant that is supplied. Also, the nuts, ive seen to do them up in 3 stages, 40/60 and 80 ft/lbs... Can anyone advise? Thanks
Thanks all Does anyone know the size of the thread/studs? Think I've found an alternative to ARP studs! http://www.ebay.co.uk/itm/Stainless-Exhaust-Manifold-Stud-Kit-Civic-EK9-EK4-EG6-/150748204405?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item23194b0d75 http://www.ebay.co.uk/itm/Rover-T-Series-Stainless-Exhaust-Studs-Locking-Nuts-/380237434697?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5887eacf49
Yeah,keep seeing everything but the exhaust kit on ebay.. No reason other than they wont rust like the standard ones and a little bit of Friday night boredom..
