might3
About might3
I have been getting a really strong smell of fuel coming in the car recently. It doesn't happen all the time though. Looking under the bonnet I can see the fuel lines going to the fuel rail but no signs of any leaks. Is it a common problem on golf vr6's?
The clutch cable feels very slack and worn on my golf so gonna replace it, seems there are two. Does anyone have any experience in this or can offer any tips? Much appreciated
Do you HAVE to get the ECU reset? If so how is it done?
Took my vr6 to the garage because it was running a bit rough on idle and light pressure acceleration. The fella there said it was something to do with not enough fuel being sent to the engine when you accelerate gently, anything more and it is fine. He then said he was going to stick a ball bearing up a vaccum pipe and this would increase fuel flow when needed. He put it on the rolling road and tested it and it improved significantly but the problem is still there slightly. I got one error message on the scanner which was an intermitent fault, something to do with a hall sensor. He asked if I
Just fitted new coil pack. Job done! Drives like a dream. Am so impressed with this engine. Thanks for your suggestions
Just had a look at the leads and noticed splits in the rubber. Can't see any arcing from the splits though. Obviously need changing anyway but does anyone think this would be enough to cause misfire?
How much oil does your vr6's use??????
might3 replied to vr6max's topic in Engine Maintenance and Problems
Mine uses about half a litre every 2000 miles. No smoke or patches either. Glad to hear it's normal. My corrado was just the same. -
L reg 80,000 miles. Serviced about 2000 miles ago. Leads don't look too old. Can't hear any arcing noises. Will have a look in the dark to see if I can see any arcs. The box does look crappy and full of cracks [ Edited Sat Mar 27 2004, 06:22PM ]
What I've got is a full on in your face misfire gradually getting worse. Have read about dodgy coil packs so will try first to see if it is. Can get it looked at by proffessionals but am strapped for cash at the moment.
Link does not work
have just been quoted £130 inc
Just bought a Vr6 Golf and it's simply awesome. May be in need of a new coil pack though. Can anyone suggest where the best place to buy from would be? I live in essex.
