wilko-vr6
About wilko-vr6
    worthing,near brighton
  1. ballasts?in r32 look in pro lights????i don't think so!for hid's,you need 20,000+volts to ignite them,then you need your relay's etc.did you up the fuses in your fusebox too mark???i run my kit with 30amp fuses as recommended with retrofit kits.i don't think the wiring is up to that in standard light units is up to withstanding the voltage of ballasts???and hid's run differently to conventional bulbs.conventional halogen bulbs are more likely to melt the lenses as the light is generated by heat as opposed to hid's burn a gas at a far cooler temperature.
  2. i heard from a good source that that golf was not chipped?????he just used a rising rate fuel pressure regulator???
  3. yippeeeeeee!done my lights!thanks you guys,it was the switch!makes it even more worthwhile being on this forum!upgrading my hid kit to a twin(dip and main beam kit now!!!!)anyone want a cheap hid kit?£250.00 is what i want for it,ono.
  4. ok you guys,my car seems to have developed a problem!no headlamps!i have my driving lamps still,my rears,my fogs,and everything else,except my headlamps!can anyone help with ideas?if i go from dip to main beam,they momentarily flash,but other than that,nothing!i measured the voltage from the live feed and have about 11.5 volts! [ Edited ]
  5. i think i'm right in saying that you really should go for a vs2?
  6. the exahaust i'm selling is the powerflow stainless system.i have to please the mrs!the decat pipe i have seen looks similar in diameter tothe system
  7. well you guys,i just got back from having a nice new magnex stainless system fitted at r-tec just north of london,and wow!it is oh so quiet,for the mrs,but too quiet for me ~ the roar of my powerflow system was awsome!but now it's gonna have to go!if anyone wants it,i'll take no less than £100 for it.however!i have another problem now!my cat has long departed the world of exhaust systems,as when the new pipe was fitted,the fitter noticed there was no sign of the internals being attached as should be so i now have to get either a new cat @£204.00 or a de-pipe@£79.00????some of my mot certifi
  8. if you take the switch out and swap quickly,it'll lose about half a pint????done mine but make sure you do it first thing in the morning otherwise it's very hot!!!!!
  9. my question would be,if you convert a coilpack engine to dizzy,does the camshaft have the provision to drive the dizzy?
  10. i can get you one for £55.42 from my main dealer!thats what i paid for mine when my one started leaking.
  11. are we talking about a cooler kit for the gearbox here?
  12. er.washing a car is important of course!was just stating that i use zymol's products.i work down by the beach.the car gets splattered in bird shit and my zymol has never let me down!gotta be the best stuff there is.anyone want a tub of meguire's gold,and the gold shampoo?used once!nuff said!
  13. i use zymol.i tried meguires and found it nowhere near as good.each to their own i say!i always follow the instructions to th bottle and my car looks stunning!i get more complements about the paint than ever having changed to it.the thing i notice you need to do with zymol is to "balance" the wax after applying it with a damp cloth!i then wash the car with zymol shampoo and hey presto!one smooth looking vr!!!!!! 8o)
