VR6SA
About VR6SA
    South africa
  1. Whats are the sure signs the clutch is slipping. My revs will go up before the car actually pulls , it happens in all the gears. Is my cluch going?
  2. Thanks. which one is the indicator relay
  3. Somethimes while driving the indicators (and hazards) will stop working, evenually it will start working again or I'll have to switch the car off and leave it for a while before it works again. Any ideas what could be causing this
  4. They produced 2 specs here, mine is the 2nd spec(obd2 I assusme) came with airbags, different headrests, oval repeaters etc not sure about engine diffrerences, colours were the same in both specs
  5. Yip its the norm around here, they never came with colour coded bumbers and archers, or 2 door or highline versions They still produce citi golfs here , wicked little machines!
  6. its 97 model so should be ob2. sorry whats a ISV
  7. Heya. When riding at low revs when i accelerate the revs will go up and then come down and then only will the car go/accelerate. It also happens when changing gear. ever since I had my throttle body cleaned its being doing this. What could it be Thanks D
  8. Yes I meant coilovers %-6 Thanks for the info Round here we dont have many places that sell them. so im a bit limited for choice. How would know if they are damping adjustable. The guy just says its imported and has no name or anything on the box D
  9. I got standard suspension and 15" wheels on my VR. I'd like to get a set of coil covers, what are the advantages of adding them and whats a good height to ajust them to. Will i loose anything in terms of comfort of the ride? Thanks D
  10. I have a cone filter and want to add some cold air. I got some flexi tubing. the problem is the tubing is to small to go over the cone and to big to go in the midlle of the cone. %-6 How do I get the tubing to fit or stay connect to the cone.
  11. my is 97 so OBD2. how do I check the lead or should I just have the agent do it . I dont have that special thingy to pull the lead from the spark plug
  12. When driving, the car somethings skips a beat , misfires I think. It sometime also happens if I floor it at pull away. Embarrassing when trying to take on a civic ! x) Had the car serviced not to long ago..any ideas what the prob is D
  13. no leaks .. how do check for air in the system
  14. Hey guys My steering has become very heavy/tight. its as if I lost the power steering. Ive check the power steering fluid and seems fine. Any ideas what the problem could be? Thanks
