robvr6
About robvr6
guisborough
ask on uk mkiv, unless you already have?
[poll] Should i sell the VR??? (plz read post b4 polling "no" :P )
robvr6 replied to c4mbl's topic in General Chat
get rid, it'll only rot sat outside -
seem to think he posts on club gti, although i might be thinking of another lizard.
nice looking car, mine a 'k' and i forgot how nice they look with those wheels on, moght even see about getting them referb'd
i think awesome sell them,
thanks all, will have to look into getting some soon,the standard ones sound crap.
need some replacement speakers for the front doors, not sure what size they are 13cm ? any recommendations ?
my front passenger side does this as well, i'm not complaining tho' because it hasn't worked at all for about a year! it's not the runners tho' because i greased them before putting the door panel back on.
first check for broken wires in the rubber boot that goes between the door and shell. if all seems ok remove the switch from the door (just pop the handle off) and clean the terminals on the switch, i've had just the same problems recently but 3 windows didn't work, 2 were down to broken wires, 1 side had 4 wires either broken or split and the other was a dodgy switch. another quick test i found to see if it is something other than wiring is test to see if the window will go up and down using the closure feature on the door lock, mine would move doing this, so sort of proved it was eithe
the light will also come on if the wire to the pads is broken, which is easy as the wire is really thin. this is what happened with mine when i got it, was advised just to join the 2 wires together,
yes i'm going, went last year and was an exellent day
Strut top is it a special nut
robvr6 replied to Justicevr6's topic in Engine Maintenance and Problems
a spark plug spanner works well too -
i'm in guisborough.
found it.
do mk3s have the dip/dim resistor like the mk2 as i can't find it, if so where is it? car is a '93 golf vr6. thanks
