jambojones10
About jambojones10
Standard headunit problem
jambojones10 replied to jambojones10's topic in I.C.E, Security an Electrical
volkswagon said if i bring my headunit in and my V5 then they will do it for free, Result!! -
are volkswagon gonna charge me for this code? -
Have put my standard headunit back in my car. It just displays "SAFE" in the display and wont do anything. Any ideas.....
How hard is it to: 1. replace the rear wheel bearings? 2. replace the front discs? 3. replace the brake hoses? cheers guys
yes the relay switches under the seat when you turn it on
The passenger one works fine so could it still be the switch? also which fuse do i check?
yes its a 94 so would have to have the tops of the bumpers colour coded aswell
Am in two minds whether to take the arches off my car and get some smooth side strips. Have had look under the arches and there a few rust bubbles so dont know whether to just leave it as it is or spend money on the side strips and arches being sprayed, what you guys think?
My 1994 vr6 keeps cuttig out mostly when engine is hot. It does it when approaching a junction or even when slowing down for a tight corner. It does it about once a day but is very annoying and could cause an accident ~ . Cleaned out ISV valve and the car has just had a service but it is still doing it, this is really bufgging me, any ideas thanks
My drivers side heat seat doesnt work! Checked wiring, relay under seat is ok. Is there anything else to check? thanks
When driving my car there is a real bad smell of petrol. Had to drive with my windows open all the time yesterday just to stop myself choking! Car seems to be running and driving fine.... any ideas
checked it again and its also came up with: 0215 - Idling speed regulation Can anyone shed any light on what this is
Just had the fault codes read on my car, its coming up with: 0319 - Brake pedal position sender - G100 How much and how hard is this to replace? Cheers
HELP - What is this?
jambojones10 replied to jambojones10's topic in Engine Maintenance and Problems
Also what tool do i need to unscrew that screw in the first picture (image 69) -
Was cleaning parts of my engine due to stalling problems. This spindle of metal came out of the part highlighted on the pictures. Is it supposed to be there. check out the pics. help cheers http://photobucket.com/albums/v692/jambojones10/Car%20Parts/
