Andyboy
Everything posted by Andyboy
  1. Did you manage to get the mounts, where did you get them from? Im looking for some for mine, the front and rear mounts. Did you notice any difference with uprated ones? Was it worth the money?
  2. I got prices for a supercharger that will fit the vr6 and was quoted £3500, i've bought mine for £210!! Its only 6 months old, and been quoted bout £250 for fitting, not a bad £500 to spend. Im hoping it takes me past 300 bhp (at flywheel) im getting a smaller/lighter pulley fitted to increase psi and getting a direct cold air feed from outside car to get maximum air in.
  3. Just bought a cooper s supercharger to fit on to my 1993 golf vr6. I've been recommended a tuning garage to fit it, they say its a relatively easy job, hust need special brackets to mount it and a air condition pulley on. I'm needing a air con pulley if anyone has one?? Has anyone ever done this before, any problems that you can see. Anything else you can think of would be greatly appreciated.
  4. Was looking on ebay, there is a brand new schrick manifold, still boxed for sale, last time i looked it was at £600. It ends in about 2 hours (about 7 tonight) so be quick!!!!!!
  5. I've got a ashley manifold on my golf, never had any problems with temperature or anything, got mine from a local supplier for £260. Noticed big difference, would advise you to get the ashley manifold. If you are worried bout the temperatures, wrap it in heat resostant tape to keep temp down.
  6. Got my cams fitted but found out my timing chain and tensioner blade are knackered! So cant test drive car!! Selling my old cams if anyones interested??
  7. Im losing bout a 1 mph round the town, worth it for that!! Got cams fitted today, cant test them as my chain and tensioner blade are F***ED!!
  8. Found out they're a set of 264 profile, getting fitted on friday!!!!
  9. Think im about 215bhp (gettin it rolling roaded next wk to see), but like they say it isn't cheap, i've spent bout £1500 so far, b ut its worth it!!
  10. Im wantin a remap after i've fitted cams and bmc filter, dont know anywhere that can do it or how much it costs?? Fitted the new throttle body 2day, WELL WORTH IT!!! Cams on friday!!!
  11. Got my cams and uprated throttle body, fitting throttle body 2moro night and getting cams fitted on thursday.
  12. I fitted a ashley manifold, decat and cat back with a filter and got 200bhp, with a set of cams aswell or an uprated throttle body would take you well over. I just got an uprated throttle body from a guy for £120 (on an exchange basis), fitting it 2moro and my cams on thursday. If you send me an email i'll give you the guys number for the throttle body. I'll let you know 2moro night what sort of difference it makes, and same on thursday with the cams.
  13. Thats great, my email address is Andrewbradshaw22@hotmail.com
  14. Dont know, i shall find out for you.
  15. There a set of fast road cams, is that what you want to know??
  16. Is the the ecu on a 1993 golf vr6 under dash aswell?? Whats the thing on the floor under the feet of the passenger in the front???
  17. Managed to get a set of kent cams from a local supplier for £383, if anyone interested contact All Sorts on 01343 550505 and mention Andy with the vr6.
  18. Sorry, which bit should I of put it in??
  19. Does anyone know the torque settings for a cylinder head, gettin it rebuilt with fast road cams, next week. Need to know the settings and bolt order for bolting it back on as well as rocker cover settings etc.
  20. I'd get him to send you a postal order, or a bankers draft, takes longer but your guarenteed (spelt wrong) to get the money!!!
  21. My drivers window wont work, passenger window is fine, I looked over the history and a new motor was fitted 18 months ago, had a look at switch and wiring seems ok. Noticed when I push the passenger window switch on my door up when window is closed my lights dim slightly. Also if car is idling and I do the same with pushing the button the revs drop as well as the lights. Can anyone help!!!! :? :? :?
  22. Does anyone know someone who can reprofile cams, i've found a company near me who will recon my head for £160, he says if I get my cams reprofiled he'll fit them. It would be easier if I could just send my head to someone else and get them to do the lot, but dont know of anyone?? &|
  23. Has anyone had there inlet manifiold ported and polished, any good??
  24. I spoke to Ian 2day, he's gonna send me a replacement throttle body, did you notice much difference??
