daimondsilver
About daimondsilver
NORTHSCOTLAND
ok. i put the bored out tb on but its idling above 1000rpm and sometimes eraticaly. I noticed that the plate had a some clearance compared to the original which looks like transision fit or slide fit. Would the small gap be the cause of the wild idling?
cheers for the replys. will it have any effect on the engine management/ fueling?
Cheers folk. what about runnung it back in? do i need to take it easy for 50 miles? its obd1 by the way [ Edited Fri Apr 22 2005, 02:58PM ]
does any soul know how to reset the ecu? is it just a case of disconnecting the battery, turning the ignition, then re connecting after a time?
just been on the lathe and bored out a spare throttle body i sourced from e-bay. Does anyone know if it can just be bolted straight on?
i have a spare obd 1 throttle body. im going to enlarge the diameter of it but would like to find the best diameter to enlarge to. Atomic motorsport enlarges to 71mm but ive heard different sizes from diferent sources. does anyone know the best size? cheers
ive bent my tie rod and the various suppliers want to know the steering rack code before they can find the part. does anyone know the code? cheers
biting brakes
daimondsilver replied to daimondsilver's topic in Wheels, Brakes, Suspension and Steering
no vermin there! its like a worn bush. i tried a pinch bar in the wishbone but theres no play. there is no play on the wheels either. -
on my 93 vr6 it seems the brakes are biting causing a thump. the calipers are a few months old. any ideas what may be causing this?? cheers
