ian sutherland
  1. where can you get the throttle body enlarged for £125 ian !alien !alien !alien
  2. i started wiggling the wires down by the oil pressure switches whilst the engine was running and the engine cut out. so i done it again and again it cut out. ripped the sensor off and found a break in the loom. £117 plus vat out of vag(bosch). £40 plus vat out of my central auto supplies also bosch. cheers anyway boys thanks for your help. ian
  3. sussed it gentlemen the crank sensor anyone got one . id really appreciate it ian
  4. cheers boys the oil level is fine. im going out today after a hard nightshift to check the oil pressure and compression check it. as im a mechanic (on trucks) i fully serviced the car and running fully synthetic mobile 1. this has foxed me but i heard a nasty story ounce about some of the vrs picking up on no 6 cylinder. anybody come across this. cheers ian %-6 %-6 %-6 %-6
  5. gentlemen bit of a story so have patience. a noise developed in the vr the other day. stripped the belt off because it sounded like a bearing. i found it was the alternator. got a price£143 plus vat. decided to strip it down to have a look and i found it was the plastic runner that the bearing sat into that was located in the housing. anyway i got a new one and fitted it and it ran perfect, on idle. now i dont know if these two items are related but i took it down the road to test drive it and it almost felt like the engine was about to seize and the oil light came on briefly.then it was fine
