Devilfish
Everything posted by Devilfish
  1. Burnt and scored CV ball bearings..... use grease next time...... &|
  2. cant see any debris in the joint but there appears to be not a lot of grease.. is this unough to cause it to seize? its free running now.. weird...
  3. mine was making a slight metallic clunking before it went, at the extreemes of steering lock. I drove my rover for 12 months before i changed them and i was ok. guess VW cv's arnt as tolerant of wear...
  4. drivers side outer i think its too dark too see at the moment thanks for the offer i'm gonna leave it till tomorrow see if i can borrow my mums vitara %-6 !dodge
  5. ill post some pics after ive figuered out how i'm gonna get to taunton tommorow for my sons christening.... took 4 hours to get recovered... and the hazards flattened the battery... very cold when you cant start the engine!
  6. If your cv joints start clicking on less than full lock CHANGE THEM AND DONT DRIVE!! nearly stuffed my VR into the central reservation as the joint collapsed jamming the steering and preventing me from turning to the right. !amazed now considerably lighter in the wallet following a 60 mile recovery Devilfish....
  7. of my car is slowly falling apart.. !amazed radiator, abs sensors... !sad now i have what i think is a wheel bearing going on the passenger side and my CV joint drivers side is making a racket when turning. ~ A few questions... I have a bearing kit from GSF is there a procedure online for replacing the bearing and is a press required for removal. The bearing i have looks like a normal, albeit large! ball race, i have only ever done the taper roller bearing type before. is it an easy job? also same question for replacing the front outside cv/uj is it an easy job? Many thanks in advance Devil
  8. VAG-COM Version: Release 311.2-N Chassis Type: 1H - VW G/J/V Mk3 Scan: 01,02,03,08,15,25,56 Address 01 ------------------------------------------------------- Controller: 021 906 256 Component: MOTRONIC M3.8.1 HS V02 Coding: 00000 Shop #: WSC 01111 1 Fault Found: 00281 - Vehicle Speed Sensor (G68) 03-10 - No Signal - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 3A0 907 379 A Component: ABS/EDS ITTAE 20 GI V00 Coding: 03604 Shop #: WSC 00000 1 Fault Found: 00290 - ABS Wheel Speed Se
  9. now i have jom indicators/fogs...
  10. i have a fault with my speed sensor... what does it do???? and do ECP sell them ???
  11. http://img.photobucket.com/albums/v612/devilfish303/side.jpg http://img.photobucket.com/albums/v612/devilfish303/reflections.jpg http://img.photobucket.com/albums/v612/devilfish303/front.jpg http://img.photobucket.com/albums/v612/devilfish303/desktop.jpg
  12. i havent posted on here for a while! as i have been so busy! a couple of piccies from work.... !alien
  13. threadlock the bolts when you put them back and torque in the correct order !
  14. mines on 17s had the camber toe and tracking done handles perfectly
  15. same symtoms here had a spark but it was weak, turend out to be a dodgy coil pack, hairline crack running round the end..
  16. i killed one racing down the a303..... not sure what they are like above 90 mph!!!
  17. you dont work for the MoD do you...
  18. is it weldable? i'd attempt to weld it up first!
  19. 34 MPG with a charger and an auto box! that seems awfully good!
  20. no worries mate just pm me and we can arrange it!
  21. 17" wheels fit fine on my slammed VR, just go for 17/35/205 tyres think my wheels are 7.5 inches wide.
  22. i can get 36-38 mpg if i coast down hills and drive like a granny... avoiding using the brakes can help too
