nedlands
Everything posted by nedlands
  1. How much should I expect to pay for having the rear axle bushes done? What's the upshot if I leave them for a bit?
  2. Check the connector between the door and a-pillar. If the connection is loose/damaged/corroded this can do all kind of weird things with your windows. Also worth ceking the condition of the cable from the connector to the motor (brown thicker cable) which can become brittle and break causing similar issues
  3. Sorted !!! Turned out to be corroded contacts on the crank position sensor - simple fix that cost 100 quid!!!
  4. I'm having a similar problem with mine but it is intermittent starting - sometimes just will not start but leave it for a few hours then it starts and runs fine. The difference with mine is that it just will not stat at all when it does this. We had to change the reader coil on our standard VR last month so it might be that and I have ordered it from the dealer although they claim that they have never had to do one before.....
  5. I'm having a problem with my VR6 which hopefully someone can help with. Around 3 days ago I went to start the car and accidentally triggered the alarm. After disarming it the car wouldn't start - it turned over fine with all the dash lights on etc. but wouldn't fire. I left it overnight and then it eventually started and ran OK. On Saturday however it did the same thing and only started again yesterday lunch time so I put it in my garage in case it was damp. When i went out this morning it refused to start again - seriously getting upset now. The car had a new coilpack fitted around 2 weeks ag
