About katconcarne
Garstang, Lancashire
ahhhhh, they fit perfectly..... drool!
my jom one has the metal lower part, you're best off checking with whoever you're buying one off to make sure. Not sure where else sells them, I got one a couple of years ago from dubfreeze. (@)
jom ones are definately better than fk as far as value for money and fit go, check out the jom one here, http://cgi.ebay.co.uk/VW-Golf-MK3-III-MK-3-Debadged-Bageless-Grill-Grille-NEW_W0QQitemZ110088740350QQihZ001QQcategoryZ43118QQrdZ1QQcmdZViewItem seems a very good price, i paid that much for mine second hand a year ago! if you don't mind paying a bit more, i really recommend the mattig 2 bar as it was superior quality and fit but alot more expensive! (@)
that's nuts, have you called him!?!
DIY turbo VR6 Corrado,updated.
katconcarne replied to CorradoVR6-n.o.s's topic in Members Rides and Event Photos
looks sweet as with the charger, and even more impressive with the turbo, interested to see how the figures compare. nice motor -
Journal VR6gaz (19/05/08) TINTS OFF
katconcarne replied to VR6gaz's topic in Members Rides and Event Photos
the seats look sweet, I have recaros in mine too, so I know how comfy they are. what wheels are you going for? -
this may be a repost, but I just saw it and think it rules so here you go: http://www.youtube.com/watch?v=d2_jUYfYyIs Your manky nutts! another awesome song and well funny And another! rocking out and laughing my ass off.... a good combo :-d Kat
spoken to the experts and had a vw specialist auto electrician look over absolutely everything and vagcom comes back with no faults, resetting the ecu has made her run slightly better but she's getting worse again, so not apermanent fix. The auto electrician is positive it's the ecu at fault and says i need a replacement. The code off mine is 021 906 258 CH, does anyone know the best place to source a second hand one? I've found a few with the letters CP at the end, will any other vr6 obd1 ecu do? or does it have to be the CH? Hope someone knows! Cheers
hi guys, does anyone know if it's possible to reset the ecu's adaptations? The latest from the garage is that because my car was running fine with 6 bent exhaust valves for the past two years, the ecu was compensating by altering the fuel mixture and now i've had the headwork done, it's not bounced back so is running really lean (not running under load at all now). So if the ecu can be reset to learn the adaptations again, the problem may be solved without a new ecu having to be sourced. Hope someone knows, Thanks, Katie PS, I tried to search for answers to this, but i kept getting a message
starting but wont move, oh no!
katconcarne replied to katconcarne's topic in Engine Maintenance and Problems
cheers pete tom's going to give the ecu a clean, see if that does owt! the auto electrician has been too busy to look at it yet. -
yeah, well frustrating, i've been 3 months now without my vr working properly, aaargh!
