tasja
About tasja
hi there I am from South Africa, I will be going to Germany(munich). Does anyone no what chips, turbos and remapping software to buy and where I can find them and the cost in EUROS. Can I remap my ecu with a vagcom or do i need special software to boost my perfomance. ANY HELP WILL BE GREATLY APPRECIATED.
hi there could anyone please help me with this problem. When I put gas it starts to sputter and then back fires. I think that it is overfuellling cause I can smell the fuel. There are no fault codes coming up.!sadPLEASE HELP
hi there i am from South Africa i have read alot about the garret chip i was wondering if there is anywhere on the net i can buy this chip from thanx
thanx for the replies i am glad to see that all you'll vr's are economical. could i get some tips on how to make my one economical
hi there i donot know if this is normal or not but on a fuel tank i get about 300km if this not normal could any one give me ideas on how to correct this. many thanx
hi there i got a few problems. firstly the idle fluctuates and the car dies it has to be restarted. secondly when i put foot it takes a while to accelerate thirdly when a accelerate there is a squikking sound can anyone please help me with these problems any help would be appretiated. many thanxs !sad
hi there please could anyone help me with an idea to modify my standards headlight or where i can find a link please i want to leave them standard. many thanks
polishing original golf vr6 rims
tasja replied to tasja's topic in Wheels, Brakes, Suspension and Steering
i have a 96 mk3 vr6 with original rims -
hi there could anyonme give give me a step by step guide on how to go about polishing these rims with out removing the tyre. any help will be greatly appreciated many thanks
hi there i found the leak it was not the platic pipe from the thermostat to the water pump. it was a plastic part behind the plastic pipe. i put heat resistant silcone in the hole and the leak stopped. i am going to go to the dealer to find out what is the name of that plastic part. thanks for all the help tasja
hi there could any one gelp me with a step by step guide on how and what to polish and the polish to use. could any show me photos of parts that have beeen polished i think she needs a new look many thanks
hi there i do not think that it is the thermostat housing cause i have just replaced about a month ago. it may be the long black pipe from the housing to the water pump. if it is how do i remove it. thanx
i have a water leak just above my oil cooler i looks like plastic,c ould anyone please tell what that part is called. many thanks
i have a 96 mk3 vr6 i have some loose wires lyling around and i donot know where they go. could any help me with a wiring diagram please or where i can fing one. many thanks
i had a coolant leak it was coming from the oil cooler the oring had broke off i replaced the oring and there was no more leak i hope this helps some one
