mulberry man
About mulberry man
hey guys just wondering if any one knows how much a new head gasket costs to get done? keep losing water like mad you can see a scummy red water mark on the left hand side of the block near the bottom inbtween the air intake and the rocker breather so i rekon it is the head gasket any had this happen? any help would be greatly appriciated cheerrs!
Highline some before and after shots!
mulberry man replied to Rikki's topic in Members Rides and Event Photos
i like the rims mate nearly swapped my bbs rc's for some but his were in need of a refurb so did not bother, he sent me some pics and he had painted the inserts mulberry it looked smart! -
yeah will do dave cheers mate
hey guys just wondering if anyone could shed light on this problem , my engine banged really hard when you dropped the gears and gave it some stick so i was pretty sure it was an engine mount but was not sure which one so i swapped the gearbox one first for vibra, this made a bit of difference but not much so a few weeks later i swapped the front one again for vibra the road one, this made alot of difference and engine movemont went down alot with only a tiny judder under harsh load but after about 3 weeks the juddder just came back but alot worse now its so bad i have to ride the clutch when
my header tank emptys in about a couple of days but only when the engine is running i cant see any obvious leeks on the pipe work, any help would be greatly apreciated cheers!
cheers mate will ring them 2 moro!
does anyone know were i could gat hold of some gti black side skirts from and for how much my sills are shagged and i want to cover them up!
yeah mate both my front and rear need replacing have you done any thing for the front?
does it still do it if you press the throttle at the same time as tou start it? mine did the same thing so i clened the throttle body and maf and it started perfectly.
hi guys seen some omp disks and pads for the front drilled and grooved for £110 just wondering if anyone has ever used tese and if they are any good?
The new vr looks a bit different! [lightbox=../../e107_files/public/1168180990_1795_FT152223_dscf0462.jpg][/lightbox]
This is what i had before my vr it was a 1.8 driver,looking back it was a bit max power but you live and learn !, let me know what you think! [lightbox=../../e107_files/public/1168030624_1795_FT0_p2130012.jpg][/lightbox]
just thought i would put some pics up of my wheels to see what you all think i coulour coded tho outer centre cap, was dam fidley!
hi guys i got a remap done on my 95 obd2 1t has a bmc and powerflow exhaust, it turns out after reading through the forum that i did not need to bother should have done my homework!, anyway the problem i have is that when the engine is warm say after 15 mins use if i switch it off and then back on again it turns over once and then dies if i do the same thing but push the throttle as i start it it fires up , also when i am slowing down to a complete stop from any speed just at the instant i stop and revs go to idle the lights go dim and the whole car judders for an instant, can i swap the new r
pretty much got exactly the same car as ian 182 only my bbs rcs have been coated in reflective hyper silver an ive coluor coded the alloy round centre ring mulberry will put some pics on soon to see what you think
