p1vsg
Everything posted by p1vsg
  1. thats smashing, cheers for the tip dude, will check that out in the morning!!
  2. i just got a diagnostic check on my abs system as the abs light kept lighting up. two fault codes came up: 00285 - abs sensor (i think) and 01276 - hydraulic brake pump. my car's a 97 VR6 obd2 i been told that by changing the sensor it might resolve the hydraulic brake problem. do you think this could be true? im having doubts im afraid. if the brake pump needs changing will the ecu need changing at the same time?? thanx
  3. i just got a diagnostic check on my abs system as the abs light kept lighting up. two fault codes came up: 00285 - abs sensor (i think) and 01276 - hydraulic brake pump. i been told that by changing the sensor it might resolve the hydraulic brake problem. do you think this could be true? im having doubts im afraid. if the brake pump needs changing will the ecu need changing at the same time?? thanx
  4. www.styledynamix.co.uk styledynamix thy charge £40 per arch inc vat!! dunno if the price will be same if u got plastic arches. its just a thought!
  5. p1vsg
    arm rest
    does any one know if there's an armrest around to fit the mk3. im looking for a black leather one for the driver in the middle. cheers.
  6. cheers for all the feedback guys
  7. cheers 4 your help much appreciated. i take it that the stealers will b da only place 2 get an oem part? do you know of any other places?
  8. hi guys, recently i have noticed my car revving up quicker above the norm. as i plant my foot right down the revs seem to shoot up about 800 - 1000 when im driving at low revs but performance doesnt seem to respond straight away, almost as if there is a lag. does this seem like symtoms of a wearing out clutch? if so what clutch wwould be reccomended as my car engine is standard and wont be charged until at least a year. thanx in advance piv
  9. looking to buy a gearbox, what sort of things should i be askin or looking for?
  10. although bbs rs's are gettn common they still look 8) . i reckon LM''s are the way forward but every1 is right, its hard finding a set in 17". i saw one mk3 on lm's an dam it looked kool. i think he's off this site aint he?
  11. will a de-cat reduce your torque if your not running a charger?
  12. http://www.performancealloys.com/details.asp?procedure=wheel&id_wheels='BBS%20LM'&id_wheels_manufacturers='BBS'&id_wheels_sizes='17x7.5'&price='434'&permission=160759645 found this site that states all wheels and fitments are avalible. ill have to get in contact with them to confirm 5x100. do you know if i can put deeper dishes onto them? guess the design 90's will have to be winter wheels if the dishes on LM's can be changed
  13. could any one reccomend any good bodyshops in the london area (dont mind traveling but not too far) as in need of rust removal. basically bought the car with the plastic arch trims and water must have got behind them and rustted up the arches. now all four arches need attention. also some rust found as you open the door at the bottom between the ruber. how much am i looking at to repair? im thinkin only the sides will need spraying? thanx piv
  14. as stated in the title im after some bbs LM's. Just wanted to know if they were split rims or just one piece. the reason i ask is that i would like to get biigger dishes put on as the effect i want is 17's x 9 inch (including a deep dish) and slammed on my konigsports. also what offset would you reccomend and are spacers needed? cheers for the help in advance.
  15. has any one had any problems with decat pipes before as im interested in getting one. also are there any reccomended pipes or is it a case of they all do the job? cheers
  16. would 2400 grade wet and dry be ok for goin over the laquer before a final polish? cheers 4 all your help much appreciated. oh and your engine bay looks heavy!! saw it in the flesh at E38 and WOW!
  17. would you know what grade wet and dry to use? another tip i've been given is to use plastic primer filler and that would give the desired effect then paint and lacqure. lets just say id like a second opinion of this
  18. does anyone know if it's possible 2 colour code the door trims because due to the texture some say that it's not possible to do. i know there is the option of fitting cl items but the problem is finding them at a reasonable price. I'd be very greatful for any info as i'll be undertaking this on my own. thanx
  19. [blockquote]Kev H "If you want punchier acceleration, dump the Autobahn orientated 3.39 diff and fit a shorted 3.68 one from a Corrado G60. It really gives the VR the acceleration the cubic capacity implies."[/blockquote] i have a 2.8 vr6 obd2, could i still achieve the same final drive (3.68) by using the one from a g60 or does this only apply to corrado's?
  20. hve to look into that one then. But do you know of anywhere that might sell them because he's too impatient. cheers
  21. does anyone know where i can buy a weld on bonnet extention. my mates after one and said its gotta be the weld on type opposed to the plastic one. any help would be great. cheers
  22. Try yourvlocal VW dealer and they should be able to get it for you as long as the part numbers mentioned previously on this thread are correct.
  23. Visited the stealers today and found out that you can get the front vortex splitter for
  24. Wil look into that, cheers mate.
  25. hi all, dunno if this is the correst section for this post so sorry if it is. i picked up a set of inpro r32 look lights from international for quite cheap and was wondering if anyone could recomend bulbs to make them look brighter. at the moment im a little dissapointed with the brightness as there are many bmw's runninng allot brighter rings. would the loom need upgrading or could i just replace bulbs (if so which ones) cheers
