matrix
About matrix
right i have replaced the coil pack with a brand new one had the diag check done which brought up maf and temp sender prob because i unplugged both while it was running after clearing the codes none came up again so it was all clear. i tried unplugging the blue temp sender tonight due to the car only running rough when its warm but it still seems to have a problem. if i hold the revs just under 3k i can feel the engine isnt running smooth its like i can feel vibration and not only at that rpm seems to go on and off at different rpm,s. what are the symptoms of a faulty cam sensor? or temp senso
just had another look at the coil pack tonight with the cover off after spraying with water i noticed verry verry slight sparks could it be enough to cause the problems im having. it needed a really good soaking before i got any sparks. anyway im hoping to get the diag test tomorrow see if that reveals anything.
something i didnt notice before just fitted a new air filter an checked the oil and happend to notice mayo on the oil filler cap and in the breather pipe from the rocker cover the small pipe coming off the induction pipe near the t/b. also checked the water and it was quite bubbly couldent see any oil though could this mean head gasket on its way out or something more serious, bearing in mind it was off the road for a couple of months and being started once a week or so.
i bought new leads just under a year ago they still seem quite supple i had all the plugs out and checked the leads but u never know with leads could be a weak or bad lead i did try spraying water all over the leads and coil pack didnt see any sparks. by the way i caoted the entire plastic part of the coil pack in a silicone compound seems to do a really good job of insulating. but it could be damaged inside could it be my temp sender as its heat related. if i had the money i would by a new maf, temp sender, coil pack and leads. is there a way to test leads with a multimeter.? the price list
just noticed it only seems like it once it warmed up?
can the temp sender cause problems also whats the idea of unplugging the maf what can doing this reveal?
also i know the coil pack is a bit dodgy but i have sealed all the cracks can they go bad on the inside. i dont want to fork out for a new one only to find its something else causing the problem.
just started happening seems to hold back untill over 3k. i have checked the leads, coil pack and plugs and cleaned the cam sensor what else could it be. thx phil
no suspension damage as im aware, i was lucky where i hit it close to the middle of the bumper where the spare wheel is so a lot of damping, but it crumpled my bonnet up damaged part of the slam panenel and crumpled the fromt part of the wing along with smashing the light all on the o/s. all the internals didnt move but could it have bent the chassis leg. when it went for the mot they found no problems.
since rear ending a range rover and having the repairs done it seems different. unless your driving verry slow it doesent want to grip on the o/s under accel and seems unbalanced under braking more lickeley to lock up on the o/s also. from purchase i think it had a slight pull under bracking but now it seems worse, when i told the garage who repaird it they said they couldent find anything bent have also had the 4 wheel alinement done so out of ideas. is it ruined forever or are there checks i can do thx phil
does a vr6 have 1 where do i find it how much do they cost. thx
how many miles do people get to a tank???
matrix replied to Ciaran's topic in Engine Maintenance and Problems
mines about 200 per tank but i drive mine hard i really have to give the vr a break also if you wanna get rid of the annoying saxo,s and corsas just take off the vr badges i never have any probs now in fact no ones interested they must think its a diesel. -
so mines running ok then even with knackered chains nice. thx for all the replies
