About NickRStorm
South Bucks
Koni shocks and H&R or Eibach springs
NickRStorm replied to matth76's topic in Wheels, Brakes, Suspension and Steering
Timing chains and head gasket
NickRStorm replied to matth76's topic in Engine Maintenance and Problems
I don't have any personal experience, but you might want to read this thread on Storm Developments from the Corrado Forum before proceeding any further. [link]http://the-corrado.net/forum/viewtopic.php?t=16972 -
You mean you've never seen the Red Devil in action? Go here & enjoy: [link]http://w005e88f.dd3418.kasserver.com/carpi/open/RedDevil_Part3.wmv
Jetex or miltec full systems..?
NickRStorm replied to mike's topic in Parts, Suppliers and Companies
I vote Milltek - I've had one on my VR Golf for 4 years & it has been brilliant, unlike the Supersprint system I had before which banged on the axle & rotted its rear box in less than 3 years Had a Jetex on my MKII GTI & it was really loud, but don't know what they're like on the VR -
The electric one is mounted vertically on the back of the engine behind the coil pack
If he doesn't, I have one I've just removed I'd be happy to part with - too noisy for my tastes! Make me an offer.
If it was me, I'd be inclined to change the oil cooler in addition to the oil & filter as they seem to have a habit of rusting and then failing at about 80K miles. It's cheap to change but can be bl**dy expensive if it fails. My first one took the HG with it & it took a lot of flushing to get all the oil out of the rad! Don't use anything but the VW oil filter as it has a buil;t-in non-return valve which the pattern ones don't. Any good quality semi-synthetic oil is suitable. Change it every 6-8 thousand miles for maximum engine life.
I've run my own IT company for the last 15 years. We do internet / network related stuff & are basically the outsourced IT dept for around 10 companies. The three VR's are company cars
Yes Personally, I wouldn't. Modern oils already have all the detergent needed to keep the engine gunge-free. Frequent oil & filter changes are the best way to keep things tip-top IMO
using a bit more oil then norm!
NickRStorm replied to jayvwvr6's topic in Engine Maintenance and Problems
I can confirm that VR's love motorway miles - one of mine's just clocked 151K (almost all motorway miles) & it's still on the original chains! Hydraulic tappets & guides were changed about 20K ago and it still uses no oil between changes (every 5K in deference to its mileage). Still a great engine and as quiet as my other 2 VR's that have half the miles! -
Firefox 1.0.6 "back" button
NickRStorm replied to NickRStorm's topic in Website Suggestions and Help
Newsflash - Just updated to FF 1.0.7 & now it doesn't seem to have this problem, so unless you've fixed it Pete, I reckon it must have been tripping a bug in the Mozilla engine. Either way, I'm happy Edit - not quite happy. It's subtly changed so that posting a reply causes the problem now !sad Works fine everywhere else though -
I have adjustable Koni's & Eibach springs on mine. It takes about 10-15 minutes a corner to adjust the ride hight (assuming the locking rings aren't siezed!). Damping is dead easy & takes seconds per corner at the front. The rear is a bit trickier as the parcel shelf mounting is in the way. One of the best ways to sharpen up the front end is to run more camber than standard, but it will cane your tyres!
Now I realise that this is a minor bug, but it doesn't make it any less annoying! When viewing forum posts in Firefox, if you hit the back button to get bak to the form list, the list is massively offset to the right by the left-hand menu being incorrectly resized. Hitting refresh will correctly display the page. I run fullscreen on a 1600x1200 screen if that makes a difference?
