nells vr6
About nells vr6
where can i get a copy of vag-com and will it run on an obd 1 car and what cables and systen requirements do i need cheers
all my worries are sorted it was the thermostat that was causing the problem i have swapped it and all problems are sorted cheers or the help guys
how easy is it to remove the thermo stat housing on the vr and how many water pipes do you have to disconnect to change the thermostat thanks guys
i need to get it checked asap as my car seems to be boiling over and the aa said it may be the gasket and i think water is getting in to the oil somewhere small traces of the dreaded mayo unless its the oil cooler
when a compression test is done what kind of results am i lookin for to suggest the cylinder head gasket as gone or on its way out just so i can compare when mine gets tested thanks
i will check them today if all these are ok it may be the headgasket
where is the thermo stat and the water pump located on the vr as i was driving home from havin an exhaust fitted when the temp warning light came on and temp went up too so i pulled over and the water had boiled away so i refilled the water and started again and within 2 miles the temp was flashing again
my car is a 1994 model with lucas front brakes should these have had warnining sensors in the pads
i didnt get any manuals with the car are there sensors on the back as well
i have two wires in the front wheel arch that dont appear to be connected to anything the wires are green and a reddish/pink colour any ideas where they should go as both sides are the same mand the wires appear to be joined together and the orange warning light on the clocks is iluminated as well
how much woul a box cost any ideas
is a vr6 gearbox the same as a mk3 gti or are they different and can you make it fit as ive been offerd a mk3vr with a duff box
im in between manchester and liverpool
my abs light is on but closer inspection the wires have been joined near the brake discs so guess what im doing on my day off this week
vr6 service and repair manual
nells vr6 replied to nells vr6's topic in Engine Maintenance and Problems
thats a great idea
