matchew
About matchew
ive never seen those wheels before?
ibiza vr6 wirring problems!!!!!
matchew replied to ibizaboy's topic in Engine Maintenance and Problems
ignore the green and blue/red one, thats for an air con connection, does the red/yellow wire have a little red plug on it? if so, this is the wire that tells the ECU the ignition has been turned on, take it to switched live. the plug in the engine bay with the red/black and black/blue wires is the reverse light wiring -
it looks like its a sheilding earth which is connected at the ecu end to ground
gti one is the same thing
do u have the correct relay in position 3 on the fuse board? #109 i think
real loss of power when warm
matchew replied to sortedvti's topic in Engine Maintenance and Problems
inlet manifold temp sender or the blue water temp sensor or both is knackerd -
Help please, gearbox problem with my VR6 possibly
matchew replied to john1980's topic in Engine Maintenance and Problems
sounds like the diffs dropped -
sounds like the person that mapped your car hasnt done it correct, as maximum power is made around 12.3:1 AFR, id say you need to get it mapped again by some one who knows what theyre doing, aslo you dont need 550cc injectors.
excellent stuff, i never knew you could run with out the MAF?, does he run anything instead of the MAF? orjust leave it unplugged? excellent results!
yeah i just got a summons because of theyre incompetance
excellent stuff, what about ecu code?
