About regs
Kent
means you dont need a service
when i took my car to the phirm i had a new ignition switch fitted and when finished the airbag light stayed on tim just cleared the codes and all was fine its not a problem you just need it on vag com
are you a debt collector oh no please dont knock on my door
VR6 Crankcase Oil Scraper/MK3 vs MK4 Sump Discussion
regs replied to cadguy77's topic in Engine Tuning
agreed with pete what damage could it cause if it breaks up -
you will get a better quality sound from 2 separate boxes a lot tighter bass
Very impressive looks like good fun
it may be your MAF
the pedal seems fine is there any way i can check to see if it is the slave cylinder without just replacing it
Just been in contact with The Phirm and they say it may be the slave cylinder is this easy to replace
I like the look of the R32 rims but they are pricy
Just wondering if anyone could help me out last night i went to drive the vr and my clutch pedal just went flat to the floor and stayed there any ideas the last couple of months ive had a ratchet sound coming from thee clutch pedal nothing seems to have snapped aroumd the pedal any help would be great
just get under the car and measure it thats the only way you will know
Sounds like the ignition switch to me i had exactly the same problem took it to the phirm and they diagnosed the problem straight away
remote start will not work if the car is in gear anyway
yeah quality
