dazzatop
About dazzatop
    darlington
  1. just found out vw sent wrong arm, & garage didnt check it! in for correct replacement free of charge:0
  2. yeah, i had a split top hose got told by garage main dealer part almost £60 i got it and fitted it myself only to be told 3 weeks later from the guy at a local radiator repairers, he could have knocked me one up for less than half that same day.
  3. Just had steering arm fitted, and track rod ends, out on test drive noticed my steering lock toward nearside which new steering arm fitted to is more than before and to the offside less than before, upon measuring the arms the new arm is 19cm the offside is 23cm the arm was a dealer part going to find out when i have some time next week, but im hoping someone could give me some advanced ammo as to which is the correct arm, or how this could have happend..ta Dazzatop
  4. I,ve got supersport coilovers on mine, u can go as low or high as you want, only thing that might put you off, they are a very stiff ride. But excellent road holding! depends what you want..
  5. That,s the way tlc cant beat it, shinier than a shiny thing. Gonna get off my arse and do a bit! Fine motor
  6. me too i used same bolts, tourqed them had a small leak nipped them up tight no more leaks. gasket was £20ish
  7. I bought my vr6 knowing it had a replacment engine its a 95m, which i presume was an 0bd1 origanally. im now thinking maybe it has a later engine what can i look for to date the engine, thanx dazzatops.
  8. mmm!! so decent standard bulbs are better? i thought led were brighter, saying that i havent noticed any motors with them, awaiting more feedback before i decide, thanx 4 feedback though
  9. Alright, ive a k&n fitted and a cat back magnex, what can i expect decatting???? performance , consumption, is it a really noticable difference, and what problems may i encounter doing it thanx!
  10. Ello, anyone out there tried these led bulbs that are on ebay? im thinking of getting rear lights 24 red brake led, and rear sidelights, also front led sidelights as the headlight is quality osram silverstar, but sidlight lets the look down, so what do you think?
  11. Hello, brothers, my near side is bent ouch! can anyone tell me can the end be replaced or is it another steering rack job. Any ideas on a quote from a garage parts and labour. thanx 4 your time dazzatop...
  12. I,ve checked my fuses a couple look a bit ropey but not blown and checking fusebox cover doesnt list it, that's the same as wifes 93 GL
  13. HI, is there supposed to be a warning tone when opening door with the lights on? Got the wife MK3 GL liked it so got myself a 95 VR6 LOVE IT! but suprised neither have audible warning???
