Hi my vr6 is occasionally cutting out when approaching junctions i.e you come down the gears then when in neutral just before stopping it cuts out. Starts again fine. Has never idled smoothly since i've had it - checked all the idle valve pipes and MAF sensor appears clean so I'm after a VAGCOM cable. Only thing is its OBD1 with the two plugs - all the ones on ebay are obd2 so any suggestions where to get one? Also any suggestions on remedy for the problem i'm having? I'm thinking a position sensor of some sort...... thanks
