Rixy
About Rixy
    Norfolk
  1. Rixy
    VR6 Cams
    coolio, stealth it'll be then, ha ha. What kinda price is a vr remap then? Is there anything i should do / make sure before i go,? I.E get the car vag com tested to make sure all sensors r working etc?
  2. Rixy
    VR6 Cams
    cool, who would you suggest? Storm, stealth, amd etc?? dont mind driving smewhere / a good distance if the mapping will be superior to a more local one?
  3. Rixy
    VR6 Cams
    so what kind of power increase can i expect from the cams then m8? My engine was fully rebuilt last year, new block, re bore to 2.9. new pistons, rings etc. All engine was lightened, balanced, hugely ported and polished etc. I have been after these cams 4 ages, so when i fit them, all i need is a 6branch, and a de cat to go with my miltek system and all will be sorted engien wise! What kinda power should i be lookin at? cheers m8
  4. Rixy
    VR6 Cams
    hi peeps, i have just bought a set of Schrick 268's for my vr finally, and have layed them next to the original standard ones, but there doesn't appear to be a huge amount of difference? WHat is the lift and duration of the standard items, and the lift / duration of the schricks? cheers?
  5. oooohhhh, i could do with a tax disc holder, lol... Will remove my crappy old clugti one then, lol.
  6. indeed, eibach's are the mutts. Cant fault them at all, never ever had a problem, nice ride, but firm when needed!
  7. SHOW UPDATE Hello all, Less than 2 weeks to go until DUBS IN THE PUB 2007 raising funds for the Air Ambulance. A show organised by Volkswagen enthusiasts for Volkswagen enthusiasts. Gates open from 3pm Friday 8th June until Sunday 10th June. The show is set on a 10 acre site and is located at the Fox Public House, A1 Southbound, Colsterworth, Nr Grantham NG33 5LN (approx. 20 miles from Stamford, Lincolnshire.) Look out for signs for the show on the way. Open to all air-cooled and water-cooled VW's or for anyone who enjoys VW's and music. There will be lots of things to see and do all wee
  8. SHOW UPDATE Hello all, Less than 2 weeks to go until DUBS IN THE PUB 2007 raising funds for the Air Ambulance. A show organised by Volkswagen enthusiasts for Volkswagen enthusiasts. Gates open from 3pm Friday 8th June until Sunday 10th June. The show is set on a 10 acre site and is located at the Fox Public House, A1 Southbound, Colsterworth, Nr Grantham NG33 5LN (approx. 20 miles from Stamford, Lincolnshire.) Look out for signs for the show on the way. Open to all air-cooled and water-cooled VW's or for anyone who enjoys VW's and music. There will be lots of things to see and do all weekend.
  9. Hi there every1, im new to the forum. I took my corrado storm off the road in october, and removed the engine. This was then taken to a local engine builders for work to begine. basically, i have had a 2.8 block rebored to take my 2.9 pistons, and have had the crank re ground and polished and head has had new valve guides pressed in, and has been skimmed. Basically, its getting close tot he put it all back together bit, and i was wondering if anyone can help me with where tog et bits from and pirices maybe? Basically, i need to know what parts the chap will need, i.e rings, big end bearings, g
  10. check out this cool new norfolk site and forum Http://www.ec-dc.co.uk
  11. Hi, im in the process of having my lump fully stripped down and rebuilt. Ive got a chap to rebuild it who has been building engine for donkeys....... But he's never done a vr, some some info would be cool if anyone knows¬! Basically, i have 2 engines with him, A Golf 2.8 AAA lump and my Raddo ABV 2.9 Lump. Both are in need of a re-bore, so the plan is as follows..:- Rebore the 2.8 block to 2.9 spec, use my pistons after cleaning and polishing, new rings, new shells etc, balanced and re-ground crank, lightened flywheel, ported polished head, new stem seals, valve guides and re seat the valves.
