jayeshjethwa
Everything posted by jayeshjethwa
  1. It's about that time to give my vr6 a long overdue TLC! Need to find a decent garage around north London that knows a vr6 inside out! Any suggestions?
  2. all other gauges are ok but now the fuel gauge has stop working complety.
  3. Hi my fuel gauge works when it wants to. normally work at the start then after driving around for 15mins it goes to zero. anyone knows or had the same proble
  4. Hi My VR has recently been leaking water because of 2 big holes at the front. I need a replacement but not sure which one to get plus i dont really wanna spend much on a rad. Jay
  5. Which one guys! Quantum Platinum 5W40 Fully Synthetic Engine Oil Quantum Synta 10W40 Part Synthetic Engine Oil
  6. Not sure if that is cause of the problem or not! still deciding to change it. The problem is when I keep my foot down there is hardly any power then there is a bust of power and then its normal again.
  7. plug the VR in and came up with this! 01247 activated charcoal filter system solenoid valve 1 n80
  8. Nahhh its not normal! I was hoping to get at least 12 mpg lol! How much mpg do you get Lukey?
  9. 20-25mpg! Thats gud considering atm mine is give me 11mpg
  10. Still haven't had the time to connect up to a VAG COM but I've been driving the car abt and like I sed before the car is fine wen it's cold but wen that temp gauge starts to move towards the middle that's wen I get the problems! All parts that were fitted are new including the maf and also forgot to mention a new coil pack!
  11. Hi guys ive been having problems with my VR and its getting really annoying now after taking it to 3 different garages. The car drives fine for the first five mins but after there is some sort of hesitation when i put my foot down it feels like the power is restricted. Also after having this problem its been drinking alot of petrol and its been giving me 11.5 MPG So far the plugs, Air flow mass, injectors have been changed and its had a full service. anyone has any ideas what it can be???
  12. I have a OBD2 AAA VR6 engine which fuel injectors do i use? Bosch 0280150953 Or Bosch 021906031a Ive got some injectors already from a friend and it has both part number on there so iam not sure!
  13. I need some advice on upgrading my rear brake on my mk3, someone has recommanded to convert the rears to a mk4 setup. What do i need to have the mk4 rear brake setup on my mk3?
  14. On the weekend i went to get the car checked over. The guy said the car is over fueling he check the plugs and they were coved with petrol. the car is also blowing out alot of black smoke. the car has a 4 bar fuel reg, it was advised to change it to 3 bar.
  15. Theres a wineing noise thats coming from the rear of the car some people have sed its the fuel pump! is that true????? :S
