About biggee30
FALKIRK
Which rear ABS sensor
biggee30 replied to ssaunders's topic in Wheels, Brakes, Suspension and Steering
What do I need to get these to fit..Cheers
biggee30 replied to biggee30's topic in Wheels, Brakes, Suspension and Steering
Any links /help on trying to find those mate much appreciated. cheers -
Simply put craggsy thanks. Is that all i will need I was thinking 10mm. If I use a spacer then will the wheel not be centarlised in the hub ie stick out further than the hub. -
NAH Fronts fouling the brake caliper!!!!!!!!! -
I know these are probably no good but I will get full face pics on tommorrow -
wheel nerd again !!! yeah but right again !! originally were 4x100 et35 - so I presume you are running adaptors ? They have the same stud pattern for the MK3 highline and fit ok that way but I think its just the offset thats different so will spacers do the job? -
Hi all I have a set of genuine vw estoril alloys that I want to put on my 97 Highline but they are a different offset size and the fronts won't turn as they are hitting the caliper. The new alloys are 6J 15" ET35 with 205/50/15 tyres I am not sure what offset the original highline alloys are but can anybody advise on what I need to get these to fit safely cheers all Graham
Thanks Bud
Marc maybe stupid questions but Is the red arrow the center cap you mention? Where is the seal the yellow or blue arrow in the picture? Where does cooler attach to the engine in the picture And from this picture is it the seal thats failed or do Ineeda new cooler cheers
Thanks Marc looks like this will be my next car DIY job
Any ideas? cheers
Well , managed to get it out WITHOUT REMOVING CALIPER/DISC. Heres how!!!!! The old one broke off with the pick up sensor still stuck in the hub when trying to get it out Shown a torch in to see the pick up sensor and lined up one of the wheel bolt holes Out she came see the difference between old and new -no wonder they go faulty The new one that I got from this guy on feebay was a bit tight going in so I cleaned up the old hole a bit and eventually it went in and bolted in http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190263016605&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_
