philtvr
Everything posted by philtvr
  1. HAd simialir in another car turned out to be a trpped wire that earthed to the body work in certain conditions, took a lot of trial and error to locate.
  2. when mine got ht a couple of weeks ago i was told if wrote off i would get a courtesy car for 1 week only. luckily it got fixed. I realise you have recipts but with out agreed value they are wothless as you could hve an old banogr with £3000 wheels its still market value of car they base it on, start trawling autotrader for similair cars to show them the value of.
  3. I checked for fault codes today with VAG.com and got the 0533 idele speed regulator 14-00 adaptaation limit(add)exceeded. Ive read on here to try cleaning the throttle body etc. With the engine running i can watch the idle , fuel etc but teh lamda boxes show no readings, does this mean its fubared is there another way to test it? thanks in advance
  4. My in laws neighbour kindly reversed into the side of my car last night. she hit between the drivers door and front wing, wing is totalled door is dented and scratched. Waiting for insurance company to get back to me, bummer!
  5. used this place years ago for some beetle parts, Abovo Write a review Imperial Works, Unit 2 Coalpit Hill, Talke, Stoke-on-Trent, ST7 1PN 01782 776340 They did a good job and when quoting had miss quoted to my advantage but stuck to the quote even though it was only verbal.
  6. My mum got one from mamas and papas to fit her corrado so she could transport my son.
  7. http://www.houseofthud.com/shifting_gti.htm This is what i used to set mine up.
  8. I had spluttering problem after i changed my plugs. turned out to be leads replaced them with new set and runs perfectly. When it was spluttering i stopped left the engine runing and looked under the bonnet in the dark revved it by and and numer 6 cylinder was having its own sparkler show, it ran fine before plug change so presume the old leads gave up the ghost when being pulled around as removed and refitted the lead several times to check it was in corectly.
  9. press clip remove plug, now there will be a u shaped clip runiing through the plastic mounting holding the sensor in slide this out to remove the sensor.
  10. Got minr from local motor factor place £80, uplug wire from top, remove two hoses. The pump is held on by 2 rubber bushes.
  11. Get a full wheel alignment done at a speacialist or a wheel place.
  12. If you think a car is designed for 12v and a mig welder is sticking in 240 odd volts you do risk frying the electronics.
  13. The noise after the car is turned off sounds like the auxilary water pump located (as you look at the engine) on the back right hand corner. You should see the water pipes running to it with a plug in the top.
  14. I have found two holes in sthe sill around the jacking points. I have cut out the rot and have made two new peices to weld in. Heres my question i have restored a few pre 75 cars from ground up but this is my first 'Modern' car. I plan to disconnect the ECU, the alternator and the battery as well as placing the earth clamp as close to the patch as possible. Anything else i should conside unplugging? thanks in advance
  15. Have you checked the adjustment on the gear cables, i had trouble getting fifth and one of the adjustment cables bolts was loose so i t was pot luck if i got it. I used this link http://www.houseofthud.com/shifting_gti.htm to check the adjustment and then found the loose nut, works a charm now.
  16. you normally either have a swirl pot or a sump in the tank so there is always fuel for the pump, filling up before it gets down to qurter of a tank, i imagine , is not what VW intended as this would be empty on the gauge if this was the case, i presume its crud in the filter or a dodgy pipe somewhere.
  17. I would start by replacing the thermostat housing as is knackered anyway then monitor water usage again. Garages can do a test for exhaust gas in the the coolant so ask for one of those but try to be there to see the result. If it comes back clear there still is a chance it has gone though. The unresponiveness could be an air leak so check all the pipes are on properly and the clips are tight.
  18. When my car gets low on petrol 1/4 -1/8 full , it will cut out going round tight corners then when straight again it kicks back in and alls fine. Once i fill up again with petrol i have no troubles till the level again gets low. Now by my amazing powers of deduction i realise its to do with petrol moving in the tank as i go round corners so there is no fuel to be drawn by the pump, is this a common problem easy fix???
  19. i used this guide when i couldn't get fifth, http://www.houseofthud.com/shifting_gti.htm
  20. I would say yes as when the suspension moves the bumpstop will move with it then when the bumpstops needed it will get compressed. As long as the dust covers covers the shock shaft its ok.
  21. Either hand brake not off properly or the fluid isn't returning out of the caliper, is the hose new may of collapsed inside?
  22. i have a problem the back have gone on fine but the front there is not enough thread to put the nut on whn the from leg is back together. The problem is where the top mount bearing sits on top of the coilover cap. On the VW leg the bearing fits onto the shock shaft on the coliover the bearing sits on top of the aluminium cap this loses about 1 cm of thread which is what i need to put the top nut on.
  23. They look good, fitting them this week end so will let you know. Give him an email about make etc
