About spanner junkie
Leicester
Engine Surging power...
spanner junkie replied to spanner junkie's topic in Engine Maintenance and Problems
I think the MAF does show up on Vagcom yes, but as i say vagcom shows nothing. Ive just changed the rotor and Dizzy cap for VAG ones but i think the bearings are on the way out in the dizzy itself! Fuel filter is new and i havnt ran the tank dry either. Does the pulsing power thing sound like it could be a fuel pump or Fuel pump relay issue? -
Hi all,ive had a few problems with my early VR recently of which i thought id sorted them all out! My problem now is...my engine feels like its surging power whilst sat at a constant speed and has twice today almost cut out kangaroo stylee!felt as if id run out of fuel but i have a nearly full tank! Its all clear on vagcom,any ideas what could be causing this please? My Dizzy is sounding noisy and im thinking it maybe on its way out as the rotor is catching the cap slightly...could this be my problem do you think? Any suggestions welcome. Andy
CrackPipe O-Ring size....
Thanks dude much appreciated,i managed to get one today and have bolted it all back up now without any leaks. -
yes i have the old one but its in a couple of pieces and its perished! I can take it to work and try and match it in the morning,but i just thought id see if anybody knew the correct size just incase i cant find one! -
Lol,After doing a few searches before posting this thread thats what i presumed people knew the long coolant pipe that goes along the front of the engine as! The only thing stopping me from bolting my new thermostat housing up is the missing o-ring! -
Hi all, I started to change my thermostat housing etc tonight only to find that i forgot to order the o-ring that goes on the end of the crack pipe! Doh!!! Anybody know what size it is please so i can pick one up tomorrow? cheers Andy
Front bearing Torque setting.....
spanner junkie replied to spanner junkie's topic in Wheels, Brakes, Suspension and Steering
On looking at a copy of the Bentley manual this morning it says..... Outer cv joint to wheel hub(with modified wheel hub) Stage 1......200Nm Stage 2......Loosen one turn Stage 3......50Nm Stage 4...... Tighten 1/12 turn..(30') I take it the initial high torque figure thats stated is to make sure the new bearing is seated correctly? -
Thanks. Am i correct in thinking the hub nut should be done up to around 200Nm/148lb ? -
I reckon it'll be alright with a bit of T-Cut lol Seriously though,it could have been a lot worse.A smashed up car is a lot better than losing someone close. Glad your missus was ok. I hope your Replacement VR is as enjoyable as this one was!
Gearshift...Am i missing something?
spanner junkie replied to spanner junkie's topic in Transmission
Absolutely Fantastic! Thanks dude. -
Thanks for having a look for me Carl. Is it a special clip?As i popped a circlip on the end yesterday and was only able to select 3rd,4th,and 5th gear! I dont suppose anybody has a picture or part number for the said clip do they? -
Thanks Carl. i just what i was thinking as there is a groove on the rod at the end of the white plastic bit! Thanks Andy -
Ever since getting my VR ive had a sloppy gearchange! Whilst changing my centre console i had a look around the gear selector and noticed that the shifter is quite sloppy and it looks like there should be some sort of circlip on the end! The question is....should there be!? This is what it looks like.... [img:width=600]http://i20.photobucket.com/albums/b226/AndyDalziel/golf/gearshift1.jpg[/img:width=600] [img:width=600]http://i20.photobucket.com/albums/b226/AndyDalziel/golf/gearshift2.jpg[/img:width=600] resized pics for you..richie Moderator edit by: richievr
