jagzVR6
Everything posted by jagzVR6
  1. I got a set for sale if your interested mate im in east london 07940150322 jag
  2. Anyone ever used these? and do they actully work theres a company on ebay selling a pair and claim they lower the front end a further 10-15mm i just wanted to know if anyones used them before Thanks
  3. I just wanted to say a big fat Fuck You to the Cunt who stole the side strips and badges of my highline yesterday. I hope you crash and die you fucking theiveing cunt!
  4. Just wandering if any one has fitted a after market tachometer on their vr6, wanted to know where to pick up the rpm feed. Car is a 97 highline obd2 Cheers
  5. Hi guys just to let you know i tried that yesterday and it worked!!! thank you RCF
  6. Thanks for the replys guys Yes the rears do defo adjust bcause the words TOP ADJUSTABLE are engraved on the dampers. Thanks RCF i will try that tommorow will let you know the outcome
  7. Hi all Ive Just bought a top adjustible koni kit for my 97 vr6 highline (yellow shocks with blue springs) and i cant seem to find how to adust the rear ones. the front ones have a little metal thing on top of the shocker which can be turned with the plastic handle supplied with the kit but the rear ones dont seem to have that metal thing on top. Can anyone tell me how to adjust the rear ones? Thank you
  8. jagzVR6
    airbox
    u got a pic of it mate, i only need the bottom half, if i like it ill send u a cheque or postal order
  9. jagzVR6
    airbox
    anyone know if a mk3 tdi airbox is the same as a vr6's i know the top half aint but is the bottom half? cos im looking to buy 1 to mod it dont want to mod my original1
  10. i got a 2 box system on my 97 highline with a de-cat and it dont sound as good as 2 pints, how come?
  11. LOL!!!!! cheers mate ill have a look tommorow
  12. Anyone know where the fuel filter is on a 97 highline and is it easy to change? much appreciated
  13. Mine used to do the same thing it ended up being the front wishbone balljoint i just changed both and it cured it
  14. I done mine a few months back and ended up dropping the rear subframe because someone told me this is the only way but now i wish i didnt because i think it stressed the steering colunm where it meets the rack. (maybe i didnt do it properly?) if i had to do it again i would take the sump off and change the gasket at the same time
  15. any1 know how to drain the old gearbox oil and add new 1? had a look underneath i c a vw badge with 2 bolts either side of it do you jus undo that? cheers
  16. hi guys, i just changed both front wishbones on my highline today and although it cured the prob i was having (creakin, clonkin etc) it now seems to have a new prob which defo was not there, the prob is when im driving an i go to slow down there is a knock which i can feel thru the steering wheel almost as if somthing is hitting the rack or the colulmn somtimes it jus does it when im driving straight, any1 got any ideas on wot this may be? thank you.
  17. hi, ive got a 97 highline with 70000 miles, my problem is on standstill when i rev it and hold it between 2000-2200rpm the engine vibrates, is this normal its always done sine i bought it does any1 elses do the same? cheers
  18. does anyone know how to raise the idle a little on a 97 highline mine somtimes drops and viabrates the car an steering, how do adjust it and is it safe to do so? ie will it affect anything else?
  19. i am thinking of changing the standard suspension on my highline, any reconmendations? dont wanna go for coilovers, jus wana know which to chose from fk's, koni's, weitec, h+r, bilstien etc,,,,,,,, cheers
  20. It dosent do it at all in a straight line it drives perfect and handles bumpy roads perfectly, it only does it wen i turn left or right off a give way or speed hump, also ive noticed it somtimes does it wen i stop to park, wen i select reverse an bite the clutch it does it?? im sure its nt cv joints. thanks for reply
  21. Hi guys, ive got a 97 golf vr6 highline with 70000 miles on the clock, its started to make a knocking cluncky noise from the front of the car when i turn left or right and the road is a bit rough, it did a few times wen i first got it but it seems to have got worse an i think its causing a bit of play in the steering wheel. anyone had the same prob on theirs? an wot is the cure? any help wud b appreciated. please help as its drivin me nuts!!! btw da car is on standard suspension. pics soon .cheers
