Hiya You just need to adjust your linkage If you look under the bonnet, you will see two cables for the linkage. The left one controls the throw from left to right on your gear nob - you can adjust it yourself. If you pull the L shape lever up and down that resembles left to right on your gear nob, i suspect when you go left on your gear nob that the actual lever under the bonnet isn't going down far enough? To remedy this you need to adjust the black piece of plastic attached to the left cable, unbolt it and angle it so you know it will push the L shape lever down further when you move your g
