ScoobyAndy
About ScoobyAndy
    Colchester
  1. update - the ONLY manual gearboxes to fit are the ones specific to the VR6 manual vans. no others will fit i'll look into wether the bellhousings are tranferable. andy
  2. i've known i the past with other manufactures that they changed the cams on some auto models, i was wondering if this was so on the VR6.....
  3. im in the process of doing this conversion myself. my donor box is from a 2.5 petrol. be warned though - you'll need a clutch any flywheel specific to the VR6 manual van - @ circa £500!! i'll know on friday how possable this is, if all goes well i can even quote a price for the whole job (i have my own garage) i'll let you know or you can give me a bell on 01206 760074 daytime Andy
  4. ScoobyAndy
    97 Multivan VR6
    if its an auto then be carefull as the gearbox will be close to dying if not already changed. If it does need a box then your looking at around the 1700+ vat area. a manual conversion may be possable.... i'll let you know on friday - when i've done mine appart from that they are pretty good vehicles. Dont know why they have less power, maybe a golf ECU will fit?? plug and play power increase!! nice if it works. Andy
  5. may be able to bring it to volkfest on sunday??? depending on how my van build goes.
  6. i have one m8e. 200 sqid. 81K and tested. i can get it to you for £60 on a pallet. 07834 356782
  7. Is there any diffrences between the engines from an auto VR6 golf to a manual??
  8. Chip is my first port of call for definate..... any suggestions as to where i can get and what sort of HP and Torque gains i can expect? Turbo or charger will DEFFINATLY happen later.
  9. Hi guys. Just bought a VR6 T4 van and wanting a bit more response from it. Could you kind folks give some advice?? induction and zorst are sorted..... andy
  10. Hi folks, I have an S-reg VR6 T4 van. What, if anything, can be done to the ECU to help produce more power? cheers. Andy
  11. Hi folks, i just bought myself a VR6 T4 van and the auto box is shot. What manual boxes will fit? does it have to come off a VR6 or are the compatible others? cheers in advance. Andy
