Damien.
Everything posted by Damien.
  1. How much on average will the Throttle body cost and the re-map ?
  2. do you think those parts are worth the 20BHP ?
  3. Is it possible, and what parts are need, how easy is it etc ?
  4. I have the metal tool. Maybe my leads are a faulty set ?
  5. Recently my car has been experiancing some miss firing. Ive replaced the plug, the leads and the coil pack, but the problem still existed. I checked the car in the dark last night and noticed small sparks where the lead joins onto the plug itself. Now im using a lead removal tool, so what could be causing this ?
  6. Ive just recently bought a removal tool. They are brilliant and a much needed peice of kit for removing leads without breaking them. Quick question on my behalf. How do you know when youve tighened the plugs enough after fitting new ones ?
  7. I need this part, as i snapped mine whilst taking off the throttle body. Whats it called and has anyone got one ?
  8. I bled my clutch system, and it was great for about 2 days. Then the problem just came back. Everytime i get into the car i either gotta do what you have to, or pump the clutch for it to start engaging. I havent got a clue whats causing it.
  9. Im looking at replacing the standard speakers in my VR6. So how big are the standard door speakers, and the rear quater speakers ? Thanks.
  10. Would large holes in the exhaust cause the car to have running problems ? I reversed into a rock the other day which ruined by back box. It fell to peices because it was so rusty and i havent had the chance to replace it yet.
  11. Intel Q6600 4 GB Crucial Ballistix Ram 8800 GTX Thats the main stuff, i havent tried water cooling yet.
  12. Haha, ok mate. I just built a new pc too, you had me spun out for a second then !
  13. I went to the gym tonight and the cars slight miss fire type problem had gotten 100 times worse. So when i got home i decided to take the spot light and check arround the engine bay. Here is what i found, do you think this would cause a problem with the running of the car ?! [mod edit resize pics] Moderator edit by: cadguy
  14. Well my cars developed a bad missfire do to a faulty lead. Im going to replace my origional leads with some nice shiney magnecor ones. But which ones should i get ? 7mm Black 8mm Blue 8.5mm Red Thanks in advance !
  15. Great. Ive ordered the low temp thermostat from awesome. Now when i replace it, is there any sort of sealant i need to put on before replacing ?
  16. Would that cause problems with the running of the car ? Also where can i find the thermostat housing and where could i buy a nice new one. Ta.
  17. Sorry, slightly off topic. Does the lead removal tool come with the car or do you have to buy one ?
  18. Ive had this problem since i got the car, i dont think its effecting the running of the car but its just one of those things which i find annoying ! hah. Anyway the temp gauge doesnt work, when im driving the car it never goes above the first set of lines, but when i park the car up and leave it running it raises to halfway. I always thought it went up to halfway and stayed there ? any ideas what the problem could be ? Thanks, Damien.
  19. Excellent, thanks for the help. Ill bleed it tonight and let you know if that sorts it. Thanks again.
  20. Thanks alot, if it needs topping up or anything how do i do that ? Sorry for all the questions.
  21. Where do i find the clutch cylinder please ?
  22. I know its the wrong part of the forums, but i dont think no one noticed this in the Gearbox and transmission section. Anyway, after leaving my car stand for a short ammount of time then goto drive it again im getting problems with the clutch. When i first get into the car the clutch pedel will just go straight to the floor as if the link between the pedel and clutch itself is broken, Ive goto "pump" the clutch for it to work again properly. Alot like when you get air out of the brake system. Any ideas what the problem is ?
  23. Did you get this problem sorted, mines doing something very very similar.
  24. Well, i left the car standing over the weekend. Got into it tonight and there is something terribly wrong with the clutch pedal. It seems to be resting closer to the floor and doesnt engage until its nearly fully down. This is a problem and its making it difficult to select gear. Anyone else had this problem ?
