Moochalargo
About Moochalargo
    Bloxworth, Dorset
  1. Hi guys ive hit the end of the road for my owning my vr6 after 9.5 years of owning it and modding it our love affair is ending! she is a 95/6 vr6 hiline in magenta. It has a new engine with.... New Rings, new big end bearings, skimmed head, new valve stem oil seals, re seated valves, new cam chain guides, lightened fly wheel,new silicone hoses, new 8mm silicone plug leads, new coil pack, new platinum plugs, new cam sensor, new lambda probe, new second hand but good cat, new engine temp sensor, new oil cooler, polished in let manifold, new serpintine belt and tensioner, k+n 57i, stainless cat b
  2. 95/6 vr hiline going cheep as has a missfire i dont have the time to solve a link to the thread on tidyvag http://s7.zetaboards.com/tidyvag/topic/8724051/1/#new thanks for looking
  3. maf changed cam sensor changed new plugs new coil pack always piston 5 getting a missfire plug gets oiled a bit! but head is crack tested only 1500 miles ago along with new valve stem oil seals and piston rings. she runs ok for a while then smokes blue which is oil then misses and runs shite. but then if driven it will smoke like mad but then stop???? ive changed the lead on 5 incase it was weak no effect and checked its sparking and it is? what can it be?
  4. got this problem started yesterday ive got a new engine and everythig was running so well then yesterday missing like a bitc and popping back firing no power stinking of fuel had a spark plug shear off in the head but got that out! new leads new plugs new coil pack and as soon as she is warm it does it again! what can i do i cant drive her anywhere like this! help help
  5. Seems to set the buzzer off at 2500 ish rpm. Oil is brad new and fine and up to level. Oil pump working well. What can this be?
  6. Oh also when driving or running if the engine is accelerated the oil light comes on and the buzzer goes off like a nut
  7. Hi guys I had a cracked block after cooking it when the serpentine belt went. After 4 rebuilds I got another engine. Rebuilt it and got it running only to be a new member to the red arrows with smoke pooring from the rear. Did new rings and shells and started it again to clouds and clouds of smoke But after a while it started to clear. I took it for a drive and it feels very retarded When I tried to time it up it had no notch on the pully wheel to denote tdc timing. How do I change the timing now it's retarded. I can't face removing the head again Please help
  8. Ok this engine is dead!! Case must be cracked as loosing all oil in to water and it's now bursting hoses lol I've been and got another engine which I believe is ok but this engine is slightly different!! The cam cover is aluminium not plastic like mine. Also the exhaust manifolds have a metal hose that connects them and then seems to go to somewhere??? My car does not have this!!! What is it?
  9. Rebuilt now. Head tested and not cracked Oil cooler bypassed. Oil still getting in to water. What can I do now? I'm out of z job at moment and this is thrashing my money! Really can't keep wasting what little money I am earning?
  10. Yeah ok thanks lads!! Going to get my bolt set and gasket later and for now bypass the cooler! I also need a part if anyone has one? The breather of the head that connects to the plastic air intake pipe has broken after being moved around so much!! Anyone got one? Cheers
  11. Had the head pressure tested cold and hot and its fine!! this makes me think that the block must have a fault somewhere or the new oil cooler i purchased may be a dud!! either way ive got to get more head bolts and another head gasket. im going to try and bypass the oil cooler to eliminate that from the question! do any of you know of a good water treatment? ive had irontight mentioned and also steel seal ive been promissed is amazing! any other ideas as i really need the car working now! its been broken for almost 4 months!!! cheers guys
  12. No that's my next step. Get it crack tested!! Going to leave it for a bit as I'm just throwing money at it now and nothing is working. Could have r32'd it by now the money I've wasted!!! Can I reuse stretch bolts? I've purchased two sets now!!!???
