boab3
  • Days Won
    20
Everything posted by boab3
  1. Im looking for the top and bottom plastics that locate the plug leads if anyone can help thanks
  2. Front knock sensor cracked aswell giving a false reading to ecu retarding ignition so awaiting new sensor. With regards to isv whats folk done with there isv?what happens to this under boost? As ive no t off the outlet of charger to throttle bodybody i was going to t into before charger but after maf so it has a suction of metered air.just i plugged vcds in and throttle angle was sitting at 33 degrees with foot off pedal ive read it should be 14 degrees but as i deleted my isv previously i screwed up the throttle screw to get a fine idle.so now im going back to setting idle angle back to
  3. Ok so was still bit rough on idle really digging deep to source whats going on.checked wires from maf and lambda back to ecu all good.crank sensir slightly below limits so i replaced it but still the same. Next up was dizzy and leads checked then last 2 things I'd forgotten about knock sensors even tho there only a microphone they retard timing by 12 degrees no good to me early spark with big injectors and lots of fuel.well turned out rear knock sensor bolt was loose sensor rattling around and its now not reading anything with multimeter.glad i had a spare new one fitted and running smoot
  4. Struggling to get a maf part number 0280 213 021 6 pin early style just wondering if anyone has used the aftermarket ones? Obviously not as good as a bosch but no options left for buying one.
  5. New green spring fitted running much better.now need to relearn ecu since its been powered down so long.good excuse to blip the right foot
  6. Well plumbed in and running its a bit better but still a bit rich.decided to have a look at valve aghhhh its been uprated to yellow spring thats 15-23psi no way will it open under vacuum with that hefty spring and very little pressure so new green spring on its way from forge thats 5-15psi so hopefully vacuum will open it easily at idle now.it is much better just now but i'll change to a lighter spring and update ASAP
  7. One for your library.handy if anyone can help translate
  8. Hi mate ive just literally plumbed it in yesterday just awaiting another silicone hose to connect to bottom of the diverter valve.here's hoping it cures my rich running at idle. I'll keep you posted
  9. Long shot here I'm after a bonrath inlet pipe if anyone can help cheers
  10. Still needing this if anyone can help
  11. http://forums.vwvortex.com/#/topics/3384376
  12. Thatd be great as ive got a mk2 16v pump im away to run but id prefer to have the mk3 tank as its easier to use.i can collect as im normally travelling the Edinburgh Glasgow areas with my job.cheers
  13. Just need 2 T pieces one to T in before charger one to T in between outlet and throttle body one vacum hose to blend in with colour scheme and 2 hoses from valve outlets to T pieces in red aswell.
  14. Postman was decent this morning eventually received my valve.
  15. Yeah slide it to either left or right i cant remember which..theres 2 pan head screws under the cover just for locating and holding cover
  16. Sorted now got a forge 007p diverter valve on its way
  17. Which part? The bit at the throttle body side just unbolts off the one at the front you unbolt the part next to dizzy or coil pack then the last part you slide it either left or right i cant remember which way
  18. Got a forge 007p diverter valve hopefully do the trick
  19. Yeah i asked for more pocket money so hopefully have a shiny one.is the standard vag one preset?whats the hose sizes for them?
  20. As above im looking for a universal bov the recirculating type if anyone can help.thanks
