j.carr82
About j.carr82
Newcastle Upon Tyne
Hi all... Unfortunately i sold my vr6 to help buy a house, miss it loads!!!!! But i never had the vibration cured.. New plugs, leads, had timing checked, belts, mounting all electrics and so on by vw and specialists but no cure.. The v dubs specialist did say it could be a worn crankshaft bearing which was £££'s to get checked/replaced so i left it, i couldn't fault the car otherwise.. good luck...
Thanks all, there is a GSF 2 miles from me so hopefully arcing stops tomorrow!!
umm bonnet stay?? i shall have a search
Thanks for that ben, i thought id need something, glad i didn't just rip them out!! and also very glad to have joined the owner club..
Coilpack buzzing after ignition off..
j.carr82 replied to j.carr82's topic in Engine Maintenance and Problems
cheers carl, popped in to a vw specialist and you were spot on.. -
I have bought new leads to hopefully solve an arcing problem, looking over the engine the leads look pretty far down.. If i just pull the old leads out am i going to struggle to fit the replacements? They are standard vw replacement leads.. Is there a tool or technic to be used or do i just go for it? i dont want to damage anything by making a stupid mistake, cheers James
Sorry for PM everybody when i first joined & thanks to all who replied. At the moment i have a vibration when the car revs hits 1400rpm - 1700rpm. Alot of people have suggested its arcing.. I have replaced the plugs as a start, Any recommendations for leads??? i have seen some split-fire ones going for £100 and they sound great but im unsure.. Also when i switch off the car the coil pack buzzes for a good 5mins before it stops. is this a sign of a broken coil pack or does it do this as std? Mountings seem ok, car is a little jerky on / off the throttle but i cant really move the engine ar
Whirring/whining noice when cold on VR6
j.carr82 replied to Dragon6's topic in Engine Maintenance and Problems
Ive recently bought a late r reg vr6 with 50k and mine has just started this now since the weather has turned a lot colder,just like you say on first start up or when its been standing a few hours atleast, Glad to hear its nothing to worry about... -
It feels like its at the front but i might be fooled, Thanks to MANZI for posting in the forum as i PM messaged everyone!! Great feed back over 40 people replied. Im replacing the plugs and leads this weekend unless i need to order leads, i reckon this will solve the problem, unless the coil pack is damaged which lots of people mentioned, also going to check the mountings and exhaust. i have noticed it backpopels quite a bit when i let off the revs. Hopefully its not the flywheel, the vibration doesn't change or get worse on releasing the clutch so don't think it is...
