Everything posted by ytzvrt
i have a spa manifold and my car is from the states lhd. im probably the only one to have this set up but been boosting and no cracks or problems. with the lifetime, how could you go wrong
help with my vrt blowing smoke!!!
ytzvrt replied to ytzvrt's topic in Engine Maintenance and Problems
anybody??? well no pcv for a vr6 means oil through the valve guides. I inquired about it with several mechanics, and they absolutely agree. Gonna give it a shot. thanks all again -
not sure what you mean, "how it goes to the fuse box" I did an 8v to a vr6t conversion and completely redid everything. If your more specific i can certainly help you.
these pistons and rings were brand new from ross racing. I also checked that i put the rings in right side up. with a decreased compression ratio. im now running 8.5:1. i know that has no bearing on this but just wanted you to know which set-up I have. -
actually i slid the piston down and pushed the rings closed with my fingers. the piston size to the bore was perefect and i was able to push them down with no struggles or difficulties. i guess i took advantage of the 15 degree difference of the bore to the top of the block and slid the rings in on an angle. again no struggles at all. by the way i tested compression in each cylinder and they all checked out. that is not to say however that i didnt crack aoil retaining ring. -
that was one mistake i used mobil1 full synth to rebuild it. I know it will never break in with this oil, so i changed it twice with conventional 5w-30. Im also thinking that since the pcv is not being sucked from the valve cover, maybe too much pressure is building up causing oil to be forced through the seals. Maybe if i hook up the exhausting side of the can back to the intake it would be more balanced to regulate pressure. -
Ok well the oil catch can doesnt even have a drip of oil in it. I did not do a compression test yet, i guess i should. Although this engine only has 200 miles on it, I was thinking that the rings might have not seated yet, which to alot of people: they think I should just drive it and let a little more time tell -
Hello everyone, I just recently finished my obd1 vrt. she runs great, with no mechanical issues, and the turbo pulls very well. When i rebuilt this motor i did everything from pistons and rings to valve guide seals and bearings. Everything was replaced. However, I noticed the other day that when i switch gears (let go of the throttle) the engine exhausts a blue smoke, which to me is definitely oil. This does not happen during acceleration or idling, so i believe the rings are ok. I know valve guide seals can do this, but mine are brand new. I have come to my own conclusion that when i fabricat
its also an obd1 so i may have the engine speed wire mated to the wrong wire at the ecu. thank you for your help
sounds like the solenoid from the avcr. it also will spike as i rev it and wont pass 1 pound of boost. I do have to change the plugs though.
Just finished my obd 1 vr6t. have a t3-04 turbo. Just started it up the other day, for the first time, and it idles smooth and reves decent. my concern is the poping noise coming from under the hood. I do have a c2 1.5 chip and an avcr boost controller, could i have this hooked up wrong or maybe the wrong plugs? Boost spikes and the avcr controller reads full throttle all the time.
Hey all, which diverter valve should i use for an obd 1 vr6 turbo application?
Can someone help me? I have an obd1 coil setup. I have low compression pistons, new bearings, arp bolts around the house, so she strong. I want 400 hp, without going standalone. I've only heard that C2 doesn't make a chip for this ecu because it is not stable enough. what should I do?
Im having the same issue.I have an obd1 coil, and want 400 horses. but am limited to c2's version turbo chip for 350 hp. Unless I get my ecu re-mapped, I can't achieve it unless I go standalone.
If you want 400hp, your gonna need stand alone, obd1 isnt stable enough to handle that much. Although there is one person on here who got his ecu re-mapped and is running 400hp.
Man that hurts. I feel your pain, the guy I bought my 95 gti from used the wrong coolant, and the head oxidized and pitted deeply. I had the same problem, but it wasn't eaten away too bad, so I milled it and I was in the clear. On the other hand, I'm stuck with obd1 too. I want to get around 400 hp, as well but not sure of the software yet. I'm open to suggestions.
thanks, 17's it is then
Anyone ever use this management? http://www.mapecu.co.nz/dealers.html Is it substantial enough? remember obd1
anyone know where I can get the inlet pipes to the turbo and intake mani, seperately? I have an obd1 and need the niple on the 90 degree pipe to the t.b.
Hello all. Just a basic question, will 18's fit my mk3?
thanks my man, it was a lucky find, but the seats came out of a jetta, so no lever on the side to fold the seat forward. So the next alternative was to re upholster the original front seats with the leather from the jetaa seats, but well worth it. The designs of the mk3 cloth seats just don't appeal to me.... at all. I had to do something
Well boys, here are some more shots, one of the leather I got from my buddy at the junk yard, get this: full leather for $175.00 american. That's about 136.74 EURO. Another interior shot of the custom gauges and relocation of radio with the avcr underneath it. http://i226.photobucket.com/albums/dd295/twin409/IMG_0029.jpg http://i226.photobucket.com/albums/dd295/twin409/IMG_0031.jpg
well the v8's are an old tradition here, cool, sound great, but the vr note comming from the rear is one of a kind and my utmost favorite, now with a t well even better, just wait till i pull up next to a mustang and wave him goodbye! I should be starting her as soon as I determine what management i'm gonna use along with the proper fabrication of the down pipe (not sure if it fits properly).
thanks alot guys, it's along time comming
Hello all, well today after two years, the powerplant is mounted in the bay, it's really exciting, can't wait to hear her run, here are some pictures...... Special thanks to my dad, couldn't have done it without you. http://i226.photobucket.com/albums/dd295/twin409/IMG_0023.jpg
