spudvr6
Everything posted by spudvr6
  1. Nice one cheers m8 going to go up to gsf saturday and get one. Thanx for the info
  2. Yeah that would be a great help m8 cheers
  3. What did you pay for that m8 if you dont mind me asking??
  4. Thanx for that m8 looked at that battery earlier, The one I had on mine was 540 cca. Will have to look into it a bit more I think. Cheers for the reply
  5. My battery has just died on my vr what I need to know is what is the correct ampage battery?? I have looked at eurocar parts and they suggest a 400 amp cold cranking but that sounds a bit weedy to me. Any suggestions guys?? Thanx in advance Pete
  6. Ported and polished throttle body make any difference on a vr?? Anyone got one or had one on there motor and did it make any difference to driveability??
  7. Got a spare maf and I think I found the problem. I have got a pipercross airfilter that kept coming off, now secured it properly. The idle sticks around 900rpm for about 10secs then drops to 750. Going to change maf and give the throttle boddy a proper clean to see if that helps. Thanks for all the replys guys you have all been very helpfull. Nice one Pete.
  8. I know if i disconnect the stepper motor on the side of the throttle body the revs drop to 750 but when i reconnect it the revs rise but no higher than a grand
  9. My 97 vr6 has a idiling problem it starts fine revs fine but when stationery it idels at 1000rpm. Somtimes it will idle at 750rpm but then starts rising.No other problems apart from that, any ideas guys?? Thanks Pete.
  10. Going to have a look at the weekend as I have a spare car I can have a look on. Will post reply when I figure it out
  11. Just put another engine and box into my vr due to cracking the last block. What I need to know is how do I adjust the linkage to select gears?? 1st no problem 2nd no problem 3rd got issues 4th no problem 5th and reverse no probs. I have also got a b&m short shift fitted. Please somebody help me it's driving me mad. Thanks in advance Pete.
  12. Hmm more research me thinks. A m8 of mine owns a garage so has all the kit bar the vagcom. Thaqnks for the info though
  13. Hi all I have got to do the abs pump on my 1997 vr. I have got a replacement all the numbers are the same. What I need to know is it just a straight forward swap?? I have read somewhere that it has to be setup is this true?? Any help will be greatly recieved. Thanks Pete.
  14. My vr keeps pulling to the right and it also keeps doing bushes in on the driver side lower arm. I have had poly bushes and it split the front one The car is on fk coilovers and I have noticed that the top of the strut the top plate is about an inch above the inner wing. Could it be I have put the top mount together wrong?? Please help as its driving me f***ing mad. Thanks in advance pete.
  15. The bushes have gone on my wishbones. I have looked through all my paperwork for the car and have noticed the wishbones have been replace about evrey 6 to 7 months is this normal?? Im going to polybush them now and was wondering where the best place is to get them from. Thanx in advance Pete.
  16. Got a 360 premium had ring of death and repaired it myself. Not had one problem with it just waiting for Forza 3 now
  17. Oh I aint changed that one cheers fella. Only changed the one in the thermostat housing.
  18. Right here we go. Turn the ignition on even when car is cold and the rad fans kick in and stay on. When I switch the ignition off with out starting the car the fans stay on for about 10mins after. Got new temp switch and it still has not worked. Problem is its killing my battery. Anybody got any ideas as its driving me mad. Thanks in advance pete.
  19. Hi everyone I have a problem with my vr. The engine has been rebuilt all top end and new chain guides. Before the engine was removed everything worked fine (bar the engine), as said has been rebuilt and put back in but now the battery light stays on. I am getting the altenator checked but I was wondering if anything else could cause this problem. All earths have been checked, all fuses checked, battery checked and I am now at the end of my teather. Is there a charging relay??? If so where and which one?? Thanks and regards in advance Pete.
  20. Mine was £396 fully comp, it's now £796. The only damage done to the other car was a scratch on his alloy. He claimed on my insurance and my insurance goes up £400..
  21. I had a bump last year (scratched wheels) and my insurance company have took 2yrs no claims off me, and put my insurance up by £400. Now this to me dont sound right to me. To say im p****ed off is a understatement. So has anyone else had this problem??
  22. No silly camber 2 new front tyres light comes on with ignition then goes out.
  23. Abs light not on but I think I will check sensors
