orangecruz
Everything posted by orangecruz
  1. no i mean if you plate over the holes for the plug leads how do you then put the leads on the spark plugs http://farm3.static.flickr.com/2612/3734916836_21c39e8b1d_o.jpg
  2. im thinking of doing this but am after some info on ow the leads are run to the plugs ect any one got any ideas please preferbly with pic cheers
  3. i need to revive ths thread thinking of running leads under my manifold can anyone give any advise please
  4. yer cheers but dont want to pay vag prices as im skint
  5. i need to replace the brown sensor on the thermostat housing on my 98 vr6 . the problem is when i have rang gsf and euro they dont know what i mean. iknow it controls the high speed van but could someone tell me the corrrect name please ?
  6. cheers rigs i wasnt after someone to do it for me but as a lot of dub things seem to be common i thought someone might havve had the same issue
  7. i thought it was the yell one but unplugged that this morn and it still happened getting sick of it now instead of nice vr roar it sounds like a sodding great hoover
  8. its running at high speed soon as ign is on i unplugged the fan sensor/swich on the rad
  9. thanks at least you have a sensible suggestion un like some cheers
  10. so is that you saying thats what it could be or just a statement is ther any way to test this unit
  11. thanks for the constructive help was thinking someone might know how to help
  12. my rad fan comes on soon as ignition is switched on unpluged fan switch but still happens , anyone have any ideas
  13. would it have any effect on the maf ?? me thinks not . if that s all it is can i remove it oh thanks for the reply
  14. when removing my wheel arch liners i came across this anyone know what it is
  15. thought the aux pump only ran when the engine of it seems mine runs with it on and turns offf when i turn the engine off if that makes sense will try the bottle then and see if its the sensor cheers
  16. right today there is now a strange whininnng noise from under the bonnet can only say its on the pass side somewhere also the temp/water light comes on weather hot or cold does anyone haqve any ideas i got a bottle from a mk3 gti but its slightly smaller so didnt fit it will it be ok
  17. get a carbonio job done and look sand sounds sweeeeeeeeeeeeeeet
  18. hmm thanks anyway which sensor on thermo housing would trigger the light on the dash do you know i have replaced the blue one about 6 months ago so hope its not that one thanks for the help
